I need guidance -Critically damped servo
Discussion in 'Homework Help' started by D.Vesa, May 21, 2015.
  1. D.Vesa
    May 3, 2015
    Mcc with Pn=3.5kW, Vn=220V, nn=3000rpm, Ra= 1.2Ohm, La=15mH, Jr=0.025kgm2, 2ΔVp=1V, Pmec+Pfe=0.0045Ω2 (Pmec=mecanic losses , Pfe=Iron losses ) , is powered through four-quadrant static convertor with Vdon=0.85V si VIGBon=2.25V from a 230V source , acts a 2000kg trolley through a mecanism with transmission factor 1m/50rpm. The dry friction coefficient between troley and the plan is 0.01.
    The requirement is :
    Using differential equation I must design a feedback control strategy for a trolley position control system in which there is no output response overshoot and with minimum possible settling time - for a step change in output position demand. I need to analyze the case of a step prescriptions position x = 2m. Analize the dinamic performance of the sistem x=x0sin(ωt). If x0=2m, untill what frequency the dinamic error will be less than 1mm. Analize the sistem if on the trolley acts a disruptive force with step variation of 2000N. What happens if the force varies sinusoidal in time ?
    What I have done untill now :
    1. I designed the convertor using the equations in simulink . I attached a picture for you to see it. (output voltage is around 220 with small fluctuation )
    2. For the Mcc I have a little problem
    here are the equations
    Va=(Rs+Ra)*Ia+La*(dIa/dt)+e ; e- is electromotor voltage and it's equal to
    Te=electromagnetic couple
    My solving attempt so far:
    Pin=I*V => I=3500/220=15,9A
