I need everyones help :)
Discussion in 'General Electronics Chat' started by Robin Mitchell, Nov 6, 2010.
  1. Robin Mitchell
    Oct 25, 2009
    738
    207
    Ok people :)
    I need everyone to tell me several IC's that they use alot and IC's that are common. Such as Memory, logic, timers, counters etc
    This means that i can make a useful IC library :)
    So lets do this, tell me now !!!
  2. nerdegutta
    Dec 15, 2009
    2,572
    807
    NE 555
    LM 358
    UA 741
    CD 4017
    PIC16F628
    For starters...
    Best of luck with you program. If you need a beta tester.... Let me know.
    Robin Mitchell likes this.
  3. nerdegutta
    Dec 15, 2009
    2,572
    807
    BTW: You should make in a language that is not OS dependent.
  4. Robin Mitchell
    Oct 25, 2009
    738
    207
    Oh, my is windows only, sorry :p
    Will work with WINE in linux
  5. thatoneguy
    Feb 19, 2009
    6,357
    718
    Not all of these are common, but they are all supported by Sourceboost C, so using them isn't out of the question, I know I have a several dozens across several categories, from 12F to 18F:
    PIC12
    PIC12C671, PIC12C672, PIC12CE673, PIC12CE674, PIC12F609, PIC12F615, PIC12F629, PIC12F635, PIC12F675, rfPIC12F675f, rfPIC12F675h, rfPIC12F675k, PIC12F683, PIC12HV609, PIC12HV615
    PIC16
    PIC16C432, PIC16C433, PIC16C554, PIC16C557, PIC16C558, PIC16C61, PIC16C62, PIC16C620, PIC16C620A, PIC16C621, PIC16C621A, PIC16C622, PIC16C622A, PIC16C62A, PIC16C62B, PIC16C63, PIC16C63A, PIC16C64, PIC16C642, PIC16C64A, PIC16C65, PIC16C65A, PIC16C65B, PIC16C66, PIC16C662, PIC16C67, PIC16C71, PIC16C710, PIC16C711, PIC16C712, PIC16C715, PIC16C716, PIC16C717, PIC16C72, PIC16C72A, PIC16C73, PIC16C73A, PIC16C73B, PIC16C74, PIC16C745, PIC16C74A, PIC16C74B, PIC16C76, PIC16C765, PIC16C77, PIC16C770, PIC16C771, PIC16C773, PIC16C774, PIC16C781, PIC16C782, PIC16C84, PIC16C923, PIC16C924, PIC16C925, PIC16C926, PIC16CE623, PIC16CE624, PIC16CE625, PIC16CR62, PIC16CR620A, PIC16CR63, PIC16CR64, PIC16CR65, PIC16CR72, PIC16CR83, PIC16CR84, PIC16F1827, PIC16F1933, PIC16F1934, PIC16F1936, PIC16F1937, PIC16F610, PIC16F616, PIC16F627, PIC16F627A, PIC16F628, PIC16F628A, PIC16F630, PIC16F631, PIC16F636, PIC16F639, PIC16F648A, PIC16F676, PIC16F677, PIC16F684, PIC16F685, PIC16F687, PIC16F688, PIC16F689, PIC16F690, PIC16F716, PIC16F72, PIC16F722, PIC16F723, PIC16F724, PIC16F726, PIC16F727, PIC16F727, PIC16F73, PIC16F737, PIC16F74, PIC16F747, PIC16F76, PIC16F767, PIC16F77, PIC16F777, PIC16F785, PIC16F818, PIC16F819, PIC16F83, PIC16F84, PIC16F84A, PIC16F87, PIC16F870, PIC16F871, PIC16F872, PIC16F873, PIC16F873A, PIC16F874, PIC16F874A, PIC16F876, PIC16F876A, PIC16F877, PIC16F877A, PIC16F88, PIC16F882, PIC16F883, PIC16F884, PIC16F886, PIC16F887, PIC16F913, PIC16F914, PIC16F916, PIC16F917, PIC16F946, PIC16HV610, PIC16HV616, PIC16HV785, PIC16LF1827, PIC16LF1933, PIC16LF1934, PIC16LF1936, PIC16LF1937, PIC16LF722, PIC16LF723, PIC16LF724, PIC16LF726, PIC16LF727
    PIC18
    PIC18C242, PIC18C252, PIC18C442, PIC18C452, PIC18C601, PIC18C658, PIC18C801, PIC18C858, PIC18F1220, PIC18F1230, PIC18F1320, PIC18F1330, PIC18F13K22, PIC18F13K50, PIC18F14K22, PIC18F14K50, PIC18F2220, PIC18F2221, PIC18F2320, PIC18F2321, PIC18F2331, PIC18F23K20, PIC18F2410, PIC18F242, PIC18F2420, PIC18F2423, PIC18F2431, PIC18F2439, PIC18F2450, PIC18F2455, PIC18F2458, PIC18F248, PIC18F2480, PIC18F24J10, PIC18F24J11, PIC18F24J50, PIC18F24K20, PIC18F2510, PIC18F2515, PIC18F252, PIC18F2520, PIC18F2523, PIC18F2525, PIC18F2539, PIC18F2550, PIC18F2553, PIC18F258, PIC18F2580, PIC18F2585, PIC18F25J10, PIC18F25J11, PIC18F25J50, PIC18F25K20, PIC18F2610, PIC18F2620, PIC18F2680, PIC18F2682, PIC18F2685, PIC18F26J11, PIC18F26J50, PIC18F26K20, PIC18F4220, PIC18F4221, PIC18F4320, PIC18F4321, PIC18F4331, PIC18F43K20, PIC18F4410, PIC18F442, PIC18F4420, PIC18F4423, PIC18F4431, PIC18F4439, PIC18F4450, PIC18F4455, PIC18F4458, PIC18F448, PIC18F4480, PIC18F44J10, PIC18F44J11, PIC18F44J50, PIC18F44K20, PIC18F4510, PIC18F4515, PIC18F452, PIC18F4520, PIC18F4523, PIC18F4525, PIC18F4539, PIC18F4550, PIC18F4553, PIC18F458, PIC18F4580, PIC18F4585, PIC18F45J10, PIC18F45J11, PIC18F45J50, PIC18F45K20, PIC18F4610, PIC18F4620, PIC18F4680, PIC18F4682, PIC18F4685, PIC18F46J11, PIC18F46J50, PIC18F46K20, PIC18F6310, PIC18F6390, PIC18F6393, PIC18F63J11, PIC18F63J90, PIC18F6410, PIC18F6490, PIC18F6493, PIC18F64J11, PIC18F64J90, PIC18F6520, PIC18F6525, PIC18F6527, PIC18F6585, PIC18F65J10, PIC18F65J11, PIC18F65J15, PIC18F65J50, PIC18F65J90, PIC18F6620, PIC18F6621, PIC18F6622, PIC18F6627, PIC18F6628, PIC18F6680, PIC18F66J10, PIC18F66J11, PIC18F66J15, PIC18F66J16, PIC18F66J50, PIC18F66J55, PIC18F66J55, PIC18F66J60, PIC18F66J65, PIC18F66J90, PIC18F66J93, PIC18F6720, PIC18F6722, PIC18F6723, PIC18F67J10, PIC18F67J11, PIC18F67J50, PIC18F67J60, PIC18F67J90, PIC18F67J93, PIC18F8310, PIC18F8390, PIC18F8393, PIC18F83J11, PIC18F83J11, PIC18F83J90, PIC18F83J90, PIC18F8410, PIC18F8490, PIC18F8493, PIC18F84J11, PIC18F84J15, PIC18F84J90, PIC18F8520, PIC18F8525, PIC18F8527, PIC18F8585, PIC18F85J10, PIC18F85J11, PIC18F85J15, PIC18F85J50, PIC18F85J90, PIC18F8620, PIC18F8621, PIC18F8622, PIC18F8627, PIC18F8628, PIC18F8680, PIC18F86J10, PIC18F86J11, PIC18F86J15, PIC18F86J16, PIC18F86J50, PIC18F86J55, PIC18F86J60, PIC18F86J65, PIC18F86J90, PIC18F86J93, PIC18F8720, PIC18F8722, PIC18F8723, PIC18F87J10, PIC18F87J11, PIC18F87J50, PIC18F87J60, PIC18F87J90, PIC18F87J93, PIC18F96J60, PIC18F96J65, PIC18F97J60, PIC18L14K50, PIC18LF13K22, PIC18LF13K50, PIC18LF13K50, PIC18LF14K22, PIC18LF14K50, PIC18LF14K50, PIC18LF2423, PIC18LF24J11, PIC18LF24J50, PIC18LF2523, PIC18LF25J11, PIC18LF25J50, PIC18LF26J11, PIC18LF26J50, PIC18LF4423, PIC18LF44J11, PIC18LF44J50, PIC18LF4523, PIC18LF45J11, PIC18LF45J50, PIC18LF46J11, PIC18LF46J50
    Add in the 74xx and 4000 series ICs, several op amps and comparators, and you've hit 60% of stuff that is looked up quite often.
    MOSFET drivers, H-Bridge controllers and drivers (L298D, example), Charge Pumps, PWM LED controlles, Maxim IC's entire line, and I think we'd be close to 75% in "robotics category" anyway.
    Most of the really useful ICs no longer have pins, some being LED Drivers, others being Xilinx FPGAs and other high density multifunction devices that also need over 60 connections.
  6. Robin Mitchell
    Oct 25, 2009
    738
    207
    That is alot of PIC chips.....
    I bet you did that on purpose, get all the pics and just stick em on :p
    I will get to work...
  7. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
  8. Robin Mitchell
    Oct 25, 2009
    738
    207
    Thanks bertus, i have never seen these chips so they are certainly uncommon :D
  9. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    4093 quad NAND Schmitt-trigger is a very useful IC.
    74HC595 is useful for port expansion. See: http://www.romanblack.com/shift1.htm
    PIC16F193x are new uC's with tons of features; B. Knutsen's shareware C compiler supports them.
    PIC16F88x are the replacement for the PIC16F87x series; good to have.
    It is very easy to overspend on parts. If you don't have a plan on what to do with them, your heirs will wind up giving them away; in the meantime they can take up lots of space.
    Better have a storage/catalog plan before you start accumulating parts. Otherwise, you will have "junque boxes" where you can't find a darn thing.
  10. tom66
    May 9, 2009
    2,613
    214
    LM339 - quad comparator
    LM393 - dual comparator
    LM311 - single comparator
    LM324 - quad op-amp, goes to ground
    LM358 - dual op-amp, goes to ground
    TL074 - quad op-amp, FET input
    TL072 - dual op-amp, FET input
    TL071 - single op-amp, FET input
    TL084 - quad op-amp, FET input
    TL082 - dual op-amp, FET input
    TL081 - single op-amp, FET input
    LM317 - adjustable positive regulator
    LM337 - adjustable negative regulator
    LM334 - adjustable current source
    78xx - positive regulator
    79xx - negative regulator
    dsPIC33F series (esp. dsPIC33FJ128GP802.)
    PIC24F series (esp. PIC24FJ64GA002.)
    AT32 series.
    Those are probably the IC's I most commonly use.
  11. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Amongst the linear voltage regulators, you'll find that you will use the LM317T, LM317L, and 7805/78L05 the most.
    The 7805 and 78L05 are the most useful of the 78xx series; you can get just about any voltage out of those you want greater than 5v by adding a resistor in series with the GND pin to GND. There's nominally 5mA flowing out of the GND pin, so the voltage output is ~5v+5mA*R1
    You need to have plenty of 0.1uF poly metal film (preferred) or ceramic caps on hand, as virtually EVERY IC and regulator requires at least one of those.
    L2722 dual power opamps are very handy, and very cheap; around $0.60/ea. You can use a single L2722 as an H-bridge to control a small (<1A) DC motor, with logic inputs. See the ST Microelectronics datasheet for example circuits.
  12. Robin Mitchell
    Oct 25, 2009
    738
    207
    Keep it comming people!!!
  13. Robin Mitchell
    Oct 25, 2009
    738
    207
    StgWookie, im not buying parts :p
    Im collecting pinouts of the most used parts so i can add them to my ChipDic
  14. tom66
    May 9, 2009
    2,613
    214
    TL431 - Shunt reference, ±2% (2.495V - 37V)
    TL431A - Shunt reference, ±1% (2.495V - 37V)
    TL431B - Shunt reference, ±0.5% (2.495V - 37V)
    TL432 - Shunt reference, ±2% (2.495V - 37V)
    TL432A - Shunt reference, ±1% (2.495V - 37V)
    TL432B - Shunt reference, ±0.5% (2.495V - 37V)
    LM4040 - Shunt reference with two pins, fixed output (available in ±0.1% version)
    TC1047A - Precision ±0.5% temperature sensor in SOT23 package
    LM2734Y - 550kHz 1A buck converter with integrated switch, 3V-20V
    LM2734X - Fast (1.6 MHz) 1A buck converter with integrated switch, 3V-20V
    LM2734Z - Fast (3 MHz) 1A buck converter with integrated switch, 3V-20V
    LT3757 - SEPIC/Inverting/Boost/Buck controller
    MCP1603 - 2.7V-5.5V fast (2 MHz) 500mA buck converter with integrated switch and boost diode
    These are some of the chips used in my Super OSD project.
  15. hgmjr
    Jan 28, 2005
    9,030
    214
    ATMEL's AVR microcontroller family of ATTINY, ATMEGA, and ATMEGAX parts.
    hgmjr
  16. tom66
    May 9, 2009
    2,613
    214
  17. Robin Mitchell
    Oct 25, 2009
    738
    207
  18. tom66
    May 9, 2009
    2,613
    214
  19. thatoneguy
    Feb 19, 2009
    6,357
    718
    No, that's not all of them. Just those supported by BoostC or BoostBasic. The full list is actually quite a bit larger than that.
    The AVR family isn't as complicated, 4 model families, a few per family, each with several package to choose from. The Attiny, for example, can be 8 pin to 20 pin.
