i need code of parallel port inputs!
Discussion in 'General Electronics Chat' started by adnan20, Jun 22, 2008.
  1. adnan20
    Dec 19, 2007
    14
    hi all :)
    this circuit of inputs
    i need code of visual basic for parallel port inputs
    for Example
    Example : if You Click any key >> END pro!
    Sorry:am not speak English :mad:
  2. adnan20
    Dec 19, 2007
    14
    understand what I mean
  3. SgtWookie
    Jul 17, 2007
    22,183
    1,728
  4. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Love the MS article. Remember when you just read or wrote to the correct offset from 3F8h?
  5. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Beenthere,
    Yep! Also remember using DOS Edit to update my Resume after copying it over via a serial port from my Model I TRS-80 to my first PC clone around 1983...
    And converting the TRS-80 Basic programs to work under MS GW Basic was a real pain in the keister (particularly the graphics-based programs designed to run on a 16-line x 64-col screen...)
  6. Wendy
    Mar 24, 2008
    20,772
    2,540
    Want a couple of used TRS80's. Still have some in my attic...
    One of the questions I would ask is what computer language is the OP (original poster) using? I still use GW and Q BASIC, been thinking of upgrading to VB, which would still leave me 10 years behind the times.
    Try this...
    http://ourworld.compuserve.com/homepages/Bill_Bowden/page6.htm#p_input
    Hehe, just found where the OP got his diagrams from.
  7. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    You will want to gouge your eyes out if you try to go go VB. It does let you do stuff in the GUI environment, but there is a cost. Sometimes, it feels like the design of the user screen is just too fiddly (personal twitch of mine). Look a Xbasic for a freebie, or Power basic if you want to do GUI stuff.
  8. Wendy
    Mar 24, 2008
    20,772
    2,540
    I'm gonig to resume this in the programing section so as to not hijack this thread. Thanks.
  9. adnan20
    Dec 19, 2007
    14
    Thank you, my brothers
    but, :confused:
    i need more ...
  10. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    It is very hard to give you a good answer when we do not know what computer and operating system you are using. Also, it would help to know the application.
    The links given by SgtWookie in post #3 are good information.
  11. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    We do not know what your langage is. Everyone writes in English on this forums. Some write in better English than others.
    If you have a friend that does speak English, they may be able to translate it for you.
    It will be hard to learn to program if you are not able to read the help files.
  12. adnan20
    Dec 19, 2007
    14
    Thank you: beenthere & SgtWookie
    my langage is Arab . forum KSA
    my operating system is xp
    Of course, good information . but i need more information for inbuts ( not Outbut)
    I know this: Out "&H378", 1
    I use a translator google
    http://www.google.com.sa/language_tools?hl=ar
    Tomorrow I will use my friend in translation
    i will complete tomorrow
