I need an urgent assistance please!
Discussion in 'Programmer's Corner' started by oath111, Dec 17, 2013.
  1. oath111
    Dec 17, 2013
    Good day! A problem shared is a problem solved. Fellows, please I need an urgent assistance in overcoming a serious challenge I'm facing interfacing my Microcontroller with a stepper motor controller PC through the parallel port.
    I am trying to fabricate locally a 3-Dimensional printer as my final year project, I've successfully constructed the machine but the technical part seems to be very tough.
    I am using a U-2 stepper motor controller/Decoder to control the stepper motors, but i don't know the exact pins of the parallel port cable the 'A-STEP, A-DIRECTION, B-STEP and B-DIRECTION' pins of the IC (as shown in the attachment) are to be connected to.
    This is urgent pls. thanks
  2. MikeML
    Oct 2, 2009
    5,451
    1,066
    Google search with the keywords "stepper motor driver ic"
    An Ohmmeter and figuring out which chip you have will answer your question.
  3. KMoffett
    Dec 19, 2007
    2,584
    234
    Mike, I think the OP is wondering which parallel port pins to connect to the IC. not sure the "microcontroller" comes in here.
    oath11, this is a pin-out for a PC parallel printer port.http://pinouts.ru/ParallelPorts/ParallelPC_pinout.shtml Your PC program will determine which of the Data Bit pins to use for the step and direction lines. Have you written the program, or you using a commercial program?
    Ken
  4. embpic
    Member
    May 29, 2013
    187
    simply to run stepper motor go through L293D stepper driver IC. which can help you to drive and simle to use.
  5. panic mode
    Oct 10, 2011
    1,329
    305
    as KMoffett already mentions, this is dependent on your software. if software does not have configurable mapping you will have to try and see. it is not hard to check though, it is just step and direction. if you choose to run in one direction (forward for example), direction signals will be fixed, but steps are changing (pulse for each step). put some LEDs on 4 incoming lines and program move (or jog) one axis at a time.
