Im trying to build this lighting circuit for a light feature Iam building. Diagram attached. Let me give a quick overview . There are two circuits . Circuit 1 is led lighting strip circuit and Circuit 2 is a mains light circuit. What I would like to happen is when the wall dimmer switch is turned on in circuit 2, the completed circuit 2 will activate the relay in circuit 1. This will complete circuit 1. When the wall dimmer switch is powered off in circuit 2 . Then circuit 1 will deactivate also as the relay switching leg 3 loses power. See diagram attached.
This is wall dimmer I am using.
ttp://pages.ebay.com/link/?nav=item.view&alt=web&id=251655906936&globalID=EBAY-GB
Can you guys give me any advice on is what type of relay can be used to do this and if my circuit is sound
