No it doesn't, but In none of your previous posts did you mention a requirement for data logging or voltage measurement.Sounds simple enough - but does not log the data, nor does it measure voltage decay. I found a device that does
If you have a bunch of different AA cells and you want to know which performs the best (for a particular load) you only need to do a comparative test i.e. apply the same load to each cell and measure how long it takes for the voltage to fall below some arbitrary threshold e.g. 1V or, less precisely, whatever voltage the clock stops working at.Why measure and not log?
by Aaron Carman
by Jake Hertz
by Duane Benson
by Jake Hertz
