Hi Everyone,
I am trying to design a simple circuit which will take a 0-5 volt control voltage and convert it to a 6-12 volt output. I was thinking of a voltage to frequency and then frequency to voltage conversion. Is there any IC which will do both on one chip? I need very small output power, in the range of only 10ma. Any other design ideas will be appreciated.
It isn't necessary that the voltage be very exact, as long as the output doesn't go below 6 volts or over 12 volts. I don't really care about linearity also as long as the voltage is basically increasing with increasing control voltage.
Thanks,
hewad
Thanks,
hewad
