I need a simple pulse activated circuit.
Discussion in 'General Electronics Chat' started by illusive, Jul 21, 2015.
  1. illusive
    Jul 9, 2015
    46
    Hello everyone!
    I need a simple pulse activated circuit. I have set up an op amp comparator which output goes high just for a split second. I need a circuit that will hold that high output level for some time (minute or more). I thing something with a 555 timer will do the job, but i'm not very familiar with that IC so i can't choose the right circuit.
    How about this circuit ?
  2. Alec_t
    Sep 17, 2013
    5,977
    1,136
    If your trigger input is a negative-going one (e.g. 5v dropping to 0V then back to 5V) you can apply it directly to pin2 0f the 555. If not, you will need a transistor stage to invert the trigger first.
  3. MikeML
    Oct 2, 2009
    5,451
    1,066
    Why not reverse the input connections to the comparator so that it outputs a negative going pulse? DUH!
  4. illusive
    Jul 9, 2015
    46
    OK, so do pulse to pin2 must be going from positive to negative voltage. MikeML, this would be the simplest solution.
    Is that all? So pin 5 is left unconnected and i just put whatever capacitor and resistor pair for the time i want the output of the 555 to be high?
    Also, lets say i want to interrupt the positive output, will a button that shorts the resistor do it?
  5. MikeML
    Oct 2, 2009
    5,451
    1,066
    Can you follow this:?
    does it do what you want? Look at the polarity of the inputs?
    Obvious improvement: add hysteresis to the comparator.
    Does the comparator need a pull-up resistor?
    Did I forget the RESET?
    absf likes this.
  6. illusive
    Jul 9, 2015
    46
    Yes i can, thanks!
  7. AnalogKid
    Distinguished Member
    Aug 1, 2013
    4,701
    1,300
    For minute-long timing periods, use the CMOS LMC555 version. It handles large timing capacitors better.
    ak
  8. illusive
    Jul 9, 2015
    46
    In inverting comparator if i want to add a 1Mohm resistor for a hysteresis where do i connect it? Between the output and the positive input or between the output and the negative input ?
  9. crutschow
    Mar 14, 2008
    13,503
    3,376
    Positive.
