I need a quick fix - help please
Gavhogg
Joined Sep 23, 2008
Hi Folks
I need help to reduce 28vdc down to 12vdc using resistors, but I'm not sure of the formula.
Can anyone help?
Many Thanks
Gavin
beenthere
Joined Apr 20, 2004
15,819
E = IR. There is no fixed formula for your application, as you don't indicate what current you wish to flow. Using fixed resistors means that the actual voltage changes with the load. Or you could get a 7812 regulator.
scubasteve_911
Joined Dec 27, 2007
1,203
Vout = Vin ( R2 / (R1 + R2))
Vin -> R1 -> R2 -> GND
Vout / Vin = (R2 / (R1 + R2))
12/28 = R2 / (R1 + R2)
One equation with two variables, bad news. As beenthere says, you need to specify current. Any current flowing out via 12V will cause the voltage to change. If the current out from the divider is much less than the current flowing through R1 and R2, then it can work. You will have a lot of power loss as you bring the resistances down to accomplish this. This is only practical for high impedance inputs, although the temperature can effect the circuit.
Steve
