I need a more powerful transistor than the Power Transistor NEC B772 2SB772 TO-126 PNP
Discussion in 'General Electronics Chat' started by easytim, Aug 10, 2016.
  1. easytim
    Aug 10, 2016
    I want one that will operate with same spec's in the circuit but only at a higher output current.
    Please help, Thank You,
    Tim
  2. Alec_t
    Sep 17, 2013
    5,979
    1,138
    Welcome to AAC!
    Depending on your circuit you may find a P-MOSFET suitable. Many types can handle very large currents.
  3. crutschow
    Mar 14, 2008
    13,509
    3,385
    As Alec noted, a MOSFET may be better.
    What exactly is the application?
  4. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
    When you show us the schematic where the 2SB is used, we will be able to offer better advice.
    Bertus
  5. absf
    Dec 29, 2010
    1,493
    374
    B772 is described as the output transistor used in 3W audio amplifier. The typical Ic(DC)=-3A and Ic(pulsed)=-7A.
    In that casing (TO-126) it is very hard to find one that exceeds 4A. But there are plenty that use TO-220 type casing.
    Attached is the datasheet of the transistor and the link below is the equilvalent (by computer) from Element14 with Ic(DC) > 3A. You can try digikey for the same engine if you're from US.
    Allen
  6. ci139
    Member
    Jul 11, 2016
    341
    39
    some people just don't realize that even if they replace a component to the very same manufacturer,model,patch,and production line - they may have to readjust the circuit for it to operate in a fist place or operate as it should . . . this is hopless
    absf likes this.
  7. ci139
    Member
    Jul 11, 2016
    341
    39
    extract from the very NEC datasheet:
    CLASSIFICATION OF hFE
    Rank R Q P E
    Range 60 to 120 100 to 200 160 to 320 200 to 400
    + another thing that is crucial for switching applications is the VCE [image] -- this is why people here suggested using the MOSFET (but it likely requires modifying the circuit . . .)
