I need a little help
Blofeld
Joined Feb 21, 2010
83
Just taking a wild guess, I'd say it's more probable that the resistor value is too high (assuming a correct circuit configuration) so that the thing can't oscillate at all. Does the LED at least show a small "flicker" if you reduce the value of the resistor ?
atferrari
Joined Jan 6, 2004
4,771
As guessing goes it well could be that it is all the time ON.
That is the good thing of the OP not posting a circuit. You guess...
