1. mustafa1987
    Mar 22, 2010
    HI every one
    my name is Mustafa and I'm a second year student at a technical institute, and I have a mini project.
    I need to generate (2 quasi-square signals must be generated. Their frequencies are 3 Hz and 3 kHz approximately)
    this will work with 5 volt
    I need your help
    thanks
  2. TheSergon13
    Mar 22, 2010
    I'm sorry for this, but I have to point it out: "I need a help" is not a good title to put on a post, mainly when everybody that uses this forum is because they need a help.
    Well, you can start by downloading a 555 datasheet here and study the typical applications. It's always one of the best places to work with an IC.
    If you want some working theory, see this.
    With a little electronic experience you can see the schematic and see how it works... It's simple
    Regards,
    Sérgio Gonçalves
  3. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Does the OP wish to use a microcontroller to generate the square waves?
  4. mustafa1987
    Mar 22, 2010
    thanks a lot monsieur Sérgio Gonçalves et Mr. beenthere
