I need a binary counter
pgo1
Joined Nov 7, 2012
67
Im looking for a 3 bit (or 4 bit) synchronous binary counter with up/down counting, a synchronous load and an asynchronous clear.
Failing that, the easiest way to fudge that from existing chips. Any ideas? I was so close with a SN74HC161N but then my spec changed and I needed to go up and down easily - I was looking at the SN74HC193 but from what I read in the datasheet the load isnt synchronous
Before anyone says it, I have looked through a parts supplier but didn't find anything - this is possibly a case of wishful thinking that I missed something
GopherT
Joined Nov 23, 2012
8,009
CD4510 should do what you want.
pgo1
Joined Nov 7, 2012
67
Thanks GopherT! The CD4510 might be the best for what I want, except the load function is still asynchronous, is that correct?
Ideally i was hoping for one with a synchronous load - I want a look ahead on the final count as i am resetting the counter at various states and ideally want a perfectly synchronous counter
GopherT
Joined Nov 23, 2012
8,009
I can't imagine there is something you could dream up that this counter cannot do. Loading preset values is synchronous.
dl324
Joined Mar 30, 2015
16,943
Load and reset on a CD4510 are asynchronous and it's a BCD counter, not binary.
If you post more information on your application, someone might have ideas for making load synchronous. Doing it only on the edge transition of the clock could require a bit of glue logic.
pgo1
Joined Nov 7, 2012
67
yes, it looked like it from the datasheet - not sure which datasheet you are looking at GopherT? The logic diagram on this one (http://www.ti.com/lit/ds/symlink/cd4510b.pdf) seems to show immediate transition at the rising edge of a signal on the preset enable
Im trying to make a counter which is preset to count to either 2, 4, 6 or 8, forward or backward, over and over. It must provide as little as possible delay between states - and preferably there should be no time difference when resetting as to when there is a state change.
Im a little pushed for space too, so although I could go down the road of extra logic, i might forego that for now and build something around a counter without a synchronous reset and see if the extra flake of time on the rest is really that problematic..
aha! I found one - SN54ALS169B
...................no i didn't. doesn't have asynchronous reset
dl324
Joined Mar 30, 2015
16,943
The TI datasheet seems to be a scan of the old RCA datasheet. The 1994 Motorola datasheet has more information (this wasn't included in the 1978 version).
The truth table clearly shows that Reset and Preset are both asynchronous. Without that information, you could look at the logic diagram and see that Reset or Preset will generate a clock and that Reset is actually implemented as a load of zero.
If you decide to pursue making load synchronous, post your schematic/block diagram so we can see how load is implemented and give suggestions.
