I need a better definition of "load"
Discussion in 'General Electronics Chat' started by fullNelson, Dec 8, 2011.
  1. fullNelson
    Nov 14, 2011
    46
    On the summary portion of the resistors page on this site, one of the summary bullets stated this:
    "Any device that performs some useful task with electric power is generally known as a load. Sometimes resistor symbols are used in schematic diagrams to designate a non-specific load, rather than an actual resistor."
    Is this applicable to only components that produce heat/light etc... as power or can I say that a (for example )transistor is a "load"?
  2. Adjuster
    Dec 26, 2010
    2,147
    300
    Clearly other power conversion devices or transducers can also be loads, such as motors, loudspeakers, earphones, transmitting antennas...
    It is perhaps less common for active devices like transistors to be regarded as loads, but they can be. Some examples:
    • Any transistor circuit (any circuit at all) is the load of its power supply.
    • A transistor / FET / vacuum tube oscillator or RF power amplifier in a transmitter, or something like a RADAR magnetron may be the load for a modulator.
    • In any multi-stage amplifier, the input of a later stage constitutes a load for the stage preceding it ("driving" it).
    • In any circuit consisting of driving and driven stages at all (including logic) we can consider circuit inputs as loads on outputs.
    • Transistors or FETs operating as current sources may be used as high-impedance loads in amplifiers, avoiding large value resistors which can be inconvenient, particularly in integrated form.
    • High-dissipation variable load devices may be built using power transistors, for testing power supplies or rechargeable batteries.
    At least that's my take on it. There are probably obvious categories missing.
  3. fullNelson
    Nov 14, 2011
    46
    A few more questions:
    What is an active device and what qualifies as one?
    Wouldn't it be enough then to say that any component which draws current and has a voltage applied to it is a load? Or is the deciding factor that the power produced by the component must be useful?
    Thanks for the response, btw.
  4. Lundwall_Paul
    Oct 18, 2011
    222
    19
    Anything that draws current.
  5. JingleJoe
    Member
    Jul 23, 2011
    185
    10
    Thats what I thought too.
    Current = Volts / Resistance, so a resistor can be used to symbolise a load and represent how much current it draws.
  6. Adjuster
    Dec 26, 2010
    2,147
    300
    Active vs passive is a bit complicated. Electronics uses a definition which some general scientists would consider incorrect, but it has become conventional.
    In essence, active devices can amplify, oscillate, perform controlled switching (most people would I think exclude electromechanical relays???) or in any situation permit a weaker controlling signal to influence a larger energy flow.
    Passive devices more simply respond to currents or voltages applied to them. This Wikipedia reference may help: http://en.wikipedia.org/wiki/Electronic_component#Classification
    It probably is true that passive devices are more commonly considered as loads, but the power dissipated does not necessarily have to be used for any particular useful purpose. One common use of a load is as a termination to a transmission line (a signal cable).
    The load is required to prevent reflection effects which can be troublesome, but if the usual resistor load is used the power absorbed by it is simply wasted as heat.
  7. GetDeviceInfo
    Jun 7, 2009
    1,571
    230
    Schematics are a language of communication. Much depends on what you are trying to convey, and to whom your addressing. If the black box, or all encompassing resistor confuses your audience, then you've errored.
  8. studiot
    Nov 9, 2007
    5,005
    515
    Life is a little more complicated than this.
    'Draws current' is too vague a term for circuit engineering
    What about a 'balanced load', an 'inductive load' and so on?
  9. fullNelson
    Nov 14, 2011
    46
    So it seems there is a division on what exactly a load is defined as. Anyone else care to chime in on what a load exactly is?
  10. Wendy
    Mar 24, 2008
    20,772
    2,540
    It is very simple. It is the device using current, no more, no less. Anything else is defining the circuit. A circuit can be a load for a battery, a terminating resistor or speaker is a load for the amplifier. A load is relative to something else.
    The point has been made that schematics are a specific language. It is a point I am in 100% agreement with. Without a schematic, it is speculation.
  11. GetDeviceInfo
    Jun 7, 2009
    1,571
    230
    I'd say, a load is anything that dissipates power, not returning it to the circuit.
  12. joeyd999
    Jun 6, 2011
    2,759
    2,943
    So, would a purely inductive/capacitive load be an oxymoron?
  13. thatoneguy
    Feb 19, 2009
    6,357
    718
    Ok:
    Any component, circuit, or combination thereof which requires a source to function. (I know, tautology)
    -or-
    Any component, circuit, or combination thereof which draws energy from a source.
  14. studiot
    Nov 9, 2007
    5,005
    515
    An earth plane for a radiating antenna is part of the load on the transmitter, but does it draw energy?
    A voltmeter is a (unwanted) forms a load, but we try to minimise the energy draw. In fact in a true null measuring system the energy drawn is zero.
  15. joeyd999
    Jun 6, 2011
    2,759
    2,943
    I think (and someone here is going to present a case that contradicts this!) that in the sense we are speaking, we are talking about electrical components and devices that are galvanically connected to a source of power. Therefore, in the case of an RF transmission system, the antenna itself would be considered the load, regardless of ultimately where the resulting RF energy was consumed.
    Perhaps the answer can be Thevinized:
    As we all know, an electrical circuit can be modeled as a voltage or current source and a series or parallel impedance. This works not only for large-signal cases (i.e. resistive/reactive networks), but also for small-signal cases (transistor, diode, other non-linear stuff).
    So, perhaps a more generalized definition of a load would be:
    "A load is that which is not a Thevinized source, and draws power (in the instantaneous sense) from the source"
    in this context, anything can be a load or a source, depending on your point of view, and how you model it. For instance, a CE transistor amp is a load on the incoming signal, but becomes a source for the next amp stage.
    Interesting, batteries can be both a source (while delivering power) and a load (on a charging circuit).
  16. MrChips
    Oct 2, 2009
    12,652
    3,461
    One cannot and should not attempt to find an absolute definition of a "load". It depends on the context and the specific focus.
    Is the shirt on my back a load? Is an infant in a baby carrier a load? Is my backpack a load? Is the baby in the womb a load?
    When does a load cease to be a burden and becomes the recipient of the energy being transferred?
  17. studiot
    Nov 9, 2007
    5,005
    515
    Hello joey,
    Well the earth plane is an integral part of the transmission system because without it, the same antenna would launch a different amount of RF power.
    So the question remains, does it draw any power?
    You didn't address my other point (about a wheatstone bridge) at all?
    Mr Chips is right - we all know instinctively what a load is but have the Devil's own job pinning down a good definition.
    go well
  18. GetDeviceInfo
    Jun 7, 2009
    1,571
    230
    I'd say yes.
  19. joeyd999
    Jun 6, 2011
    2,759
    2,943
    Tell that to the power company! They charge industry for low PF (even though its *their* wires that are dissipating the power).
  20. GetDeviceInfo
    Jun 7, 2009
    1,571
    230
    well, it's the resistive component that dissipates the power, and they already know, so telling them is mute.
    The penalty isn't about giving it back, it's when you give it back. If you give it back on top of your regular load, there's implications in transmission capabilities. If you gave it back instead of your regular load, they might actually pay you for it.
