I need 24v from M2170 Multi Tap - Help me with Diagram and Wiring it up
Discussion in 'The Projects Forum' started by CRAIG VANDEKAMP, May 14, 2015.
  1. CRAIG VANDEKAMP
    May 14, 2015
    20
    I have a Powertran M2170L multi tap transformer; I want to wire up to a 24 volt pinball machine
    (rated at 24v AC 3A 100VA);
    I am totally confused with the wiring Diagram on the top of the transformer (see picture)
    How do I wire this up? How I read it is A,E go to the pinball power and B-F are connected together (jumper)
    is this right
    This is the manufacturers DIAGRAM for the transformer:
    Hope someone can figure this out for me! Thanks Folks.
    Craig.
    Moderators note: removed link.
    You can put it up as homepage in your profile as soon as you reach a postcount of 10
  2. MaxHeadRoom
    Jul 18, 2013
    10,867
    2,528
    You use A & E for the 24v circuit and jumper B & F.
    This would then series up the two 12v windings.
    Max.
  3. CRAIG VANDEKAMP
    May 14, 2015
    20
    Thanks mate; 1:45am in the morning here in Australia; so I will give it a try tomorrow(today) yawn; need some sleep before playing with electrons :) safety first.
    Craig
  4. CRAIG VANDEKAMP
    May 14, 2015
    20
    A few questions relating to the 250v primary side wires and fuses for both primary and secondary sides
    1. which wire is live? - (I think this -> BROWN = live current 240v and BLUE= common 0v)? (this complies with Australian standards)
    2. where do I put the recommended 500mA fuse? - on the primary side or secondary side?
    3. what size fuse should I use on the secondary side? - (I'm thinking [100va div 24v = 4.16A] -- so 5A should do - is this correct as pinball is rated at 24vac : 3a : 100va);)?
  5. MaxHeadRoom
    Jul 18, 2013
    10,867
    2,528
    Yes. The 500ma fuse states on the primary, wire into the hot/live conductor.
    100va/24 = ~4amps, so a 5 amp would be suitable.
    Max.
  6. CRAIG VANDEKAMP
    May 14, 2015
    20
    thanks mate; you're a legend
  7. MaxHeadRoom
    Jul 18, 2013
    10,867
    2,528
    You haven't hooked it up yet!:p
    Max.
