i must be really stupid
oli p
Joined Nov 24, 2008
7
i have started a new course at college as a part of my apprentiship, and have been set an asignment.
for one of the questions i have to find out the voltage across two resistors.
i have found out that
Resistor 1= 5 ohms
R2= 7 ohms
Voltage is 12V
and the current flow is 1 amp
but now i have to find out what the voltage drop across each of the resistors is . . . .
i have no idea how to do it
please please can anyone help me???
thanks oli
KL7AJ
Joined Nov 4, 2008
2,229
Resistor 1= 5 ohms
R2= 7 ohms
Voltage is 12V
thanks oli
Ohm's Law is your friend: E=IR.
oli p
Joined Nov 24, 2008
7
is that the same as V=IR
but the voltage is shown as E??
and i no i do sound really stupid but how do i use that to find the drop?
thanks
oli
oli p
Joined Nov 24, 2008
7
yeah i thought that
but still, i am quite dense
so how could i use that to get the voltage drop across the two seperate resistors?
thanks
oli p
Joined Nov 24, 2008
7
so
if i go
V=IR
12V=1A x 12ohms
and then
12-12=0
so the voltage drop is 0
is that right??
anyone
please?????
Wendy
Joined Mar 24, 2008
23,421
Yep, but you want individual voltages across each resistor. The 2 voltages (2 resistors) should add up the the power supply feeding them.
floomdoggle
Joined Sep 1, 2008
217
Are these resistors in series or parallel?
This is not a trick question, but it is a trick. 5 ohm resistor should have 7 volts, 7 ohm, 5volts, should be the voltage drop. Can't believe the Sarge missed this. Please don't shoot me, I'm only the handyman.
Dan
Audioguru
Joined Dec 20, 2007
11,248
Dan
No.
1A through 5 ohms produces a drop of 5V, not 7V.
1A through 7 ohms produces a drop of 7V, not 5V.
SgtWookie
Joined Jul 17, 2007
22,230
Dan
I didn't miss it. But since it seems to be a homework problem, I didn't simply want to give him the answer.
Since the source voltage is 12, the circuit current is 1A, and there are two resistors valued at 5 Ohms and 7 Ohms, the only possible configuration is that the resistors are in series.
This is rationalized by Ohm's Law: I=E/R, or Current = Voltage / Resistance.
Since E=12 and I=1, R must be configured as 5 Ohms + 7 Ohms = 12 Ohms, so that I=1.
Flipping Ohm's Law around, E=IR, or Voltage = Current x Resistance.
We already know that I=1.
The remainder of the problem should not be too difficult to figure out.
dyeraaron
Joined Oct 27, 2008
57
you say you have 12 VDC and 2 resistors which are 5 ohms and 7 ohms....with 1 amp for current flow............
well 5 ohms plus 7 ohms = 12 and so if these resistors are in series which i assume they are.....12 volts / 12 ohms = 1 amp...but now you take 1 amp * 7 ohms = 7 volts across that resistor and same for 1 amp * 5 ohms = 5 volts.........Kirchoffs law is you friend as well.......what goes in must come out
floomdoggle
Joined Sep 1, 2008
217
If I goofed up giving out the answer, I am sorry. I remember this question from basic electronics back in the 70's. Can't believe they are still teaching the same story problems from 30 years ago. My apologies to all.
Dan
scubasteve_911
Joined Dec 27, 2007
1,203
I used to think this was silly to be learning such old stuff, but now I am glad. I am learning stuff from 1864 right now (Maxwell's equations!). Does this make engineers useful out of school, no! But does it give them potential, yes!
Fortunately for me, I started tinkering at a young age and have a lot of practical experience.
Steve
SgtWookie
Joined Jul 17, 2007
22,230
Dan
Dan,
It's not just that you tried to give an answer, you gave an incorrect answer. I don't know how you could possibly have come up with 5v across a 7 Ohm resistor and 7v across a 5 Ohm resistor when the total voltage is 12V and total current is 1A.
The problem is that the answer you gave may have confused the dickens out of the original poster.
Rather than simply solving what might seem to be (an) elementary problem(s), I try to refer students to resources that will enable them to figure out the problem themselves.
floomdoggle
Joined Sep 1, 2008
217
Sarge,
It is not that I gave an incorrect answer, it is that this is a trick. I got a B+ instead of an A because of this question. Try it again, I've never figured it out. I say this with all due respect.
Dan
