I made an led clock!
Discussion in 'The Projects Forum' started by bugminer, Jun 25, 2014.
  1. bugminer
    May 10, 2014
    I made a clock using the NTE2061 ic. Also found that it's a very close match to the Philips ECG2061.
    I was helped by info I found on these forums that was posted by k7elp60.
    Brownout, tshuck and ErnieM like this.
  2. Brownout
    Jan 10, 2012
    2,375
    998
    Congratulations! Now for the schematic....
  3. atferrari
    Jan 6, 2004
    2,666
    784
    What is the actual time? c6 : 42 or |6 : 42?
  4. takao21203
    Distinguished Member
    Apr 28, 2012
    3,578
    463
    When I was young I always wondered what's inside these ICs and how do they actually work. I disassembled a lot of appliances but not having much of a clue.
    Then I stopped for many years, became occupied with computers...
    Interesting to see the pricing when looking for this IC, if I would charge such prices on my ebay...
    Not bad for a first time project? Is it?
  5. Brownout
    Jan 10, 2012
    2,375
    998
    My guess is 6:42pm.
  6. bugminer
    May 10, 2014
    Brownout is correct, That led on the left is for pm and the one above it is for am.
    I've attached a quick drawing of how I hooked it up, for more info see:
    http://www.nteinc.com/specs/2000to2099/pdf/nte2060.pdf
    http://www.datasheetarchive.com/dlmain/Datasheets-112/DSAP0045831.pdf
    The circuit in the pdf can be a bit confusing (it was for me at least).
    Obviously, you'll need to adjust the resistor values for the displays according to the voltage you are using etc.
