I love vacuum tubes
Discussion in 'Off-Topic' started by KL7AJ, Feb 11, 2016.
  1. KL7AJ
    Thread Starter AAC Fanatic!
    Nov 4, 2008
    2,043
    292
    Interesting history:
  2. profbuxton
    Member
    Feb 21, 2014
    233
    68
    I would too, if there was any thing in it!
  3. KL7AJ
    Nov 4, 2008
    2,043
    292
    0 is a number, too!
  4. Lestraveled
    May 19, 2014
    1,957
    1,217
    The sound of Rock n Roll is based on the vacuum tube. With all of the engineering poured into it over the years, nothing replaces it.
  5. nsaspook
    Aug 27, 2009
    3,006
    2,348
    Most of my early shipboard technician life was spent working on vacuum tube technology equipment. I didn't love tubes then and I don't love them now. Try maintaining a room filled with 390 receivers, a tasks group src20 set or a spa-8 in the tropics with minimal or no AC in the room. Love is not the word I would use for that experience.
    JoeJester and atferrari like this.
  6. Glenn Holland
    Member
    Dec 26, 2014
    359
    114
    It's a lot like the old fashioned elevators with mechanical selectors, relay logic and AC/DC motor generator sets.
    They're fun to watch and listen to, but a pain in butt to whoever maintains and repairs them.
  7. Hypatia's Protege
    Distinguished Member
    Mar 1, 2015
    2,829
    1,305
    So do I!:D:D:D
    For the record --- Only at such time as EUV through 'hard' X-Rays (to at least 100 MeV) may be produced via semiconductor devices (composed of stable nuclides/isotopes) might one argue that electron tubes are wholly obsolete -- Then too, such indispensable (and ubiquitous) instruments as EMs, MSs and, indeed, all manner of particle accelerators, are, in essence, 're-entrant' electron tubes...
    But here's a thought -- The Crookes tube (which being an experimental/demonstration CRT and X-Ray tube) is often cited as the earliest electron tube -- The irony (such that it is) being, inasmuch as a 'semiconductor realization' of the latter function is unlikely, that one is put in mind of the Bard's immortal line: "She, she at least, shall stand to the last even as she was first..." (Possible [proximate] paraphrase)...:cool:
    Best regards
    HP:)
  8. ISB123
    May 21, 2014
    1,240
    531
    I hate Vacuum tubes but I love Nixie tubes:oops:.
    nsaspook likes this.
  9. nsaspook
    Aug 27, 2009
    3,006
    2,348
    Tube are not obsolete but are (thank goodness) no longer general purpose devices for electronics.
    I'm still the 'tube' guy.:p
    http://forum.allaboutcircuits.com/threads/tube-creep.113198/#post-880679
    Hypatia's Protege likes this.
  10. #12
    Nov 30, 2010
    16,655
    7,293
    Quote from some old guy disparaging transistors: "There is nothing a tube can do that 5 or 6 transistors can't do.":cool:
    I assume he was thinking about a pentagrid converter.
    I also assume he was wrong about high energy circuits. There is definitely a limit to how much voltage you can connect to the pins of a TO-220 package.:D
    In reality, 5 or 6 transistors still require less power than a pentagrid converter.
    And while I'm here, I would like to discourage people who say transistors don't wear out. They don't get low emission from their cathodes, but ECG and I made a living replacing transistors that failed.;)
    Sinus23 and Hypatia's Protege like this.
  11. nsaspook
    Aug 27, 2009
    3,006
    2,348
  12. KL7AJ
    Nov 4, 2008
    2,043
    292
    I bench pressed a LOT of R-390s into racks....singlehandedly. And I STILL love them!
  13. KL7AJ
    Nov 4, 2008
    2,043
    292
  14. JoeJester
    Apr 26, 2005
    3,387
    1,211
    Hey, they even made a phantastron oscillator using transistors. Of course the vacuum tube model was a pentode.
    I remember lugging around those old Tektronix scopes.
    nsaspook and Hypatia's Protege like this.
  15. Hypatia's Protege
    Mar 1, 2015
    2,829
    1,305
    My principal 'gripe' with 6BK4s (and their ilk) was the @#$% 'integral shielding':mad: --- That said, 80keV shines on through quite nicely!:D:D:D -- No kidding! 6BK4s and 6EN4s will 'take' upwards of 100kV (cold 'cathode' inverse polarity) sans internal flash-over (following Ca. 1 hour 'pre-seasoning' in normal, forward operation [i.e. ≈ 20kV @ 5mA]) --- Needless to say, said off-label operation requires immersion in dielectric oil -- To my erstwhile youthful perspective, the apalling focal geometry was adequately compensated by economy:cool::cool::cool:
    Nostalgically
    HP:)
  16. Hypatia's Protege
    Mar 1, 2015
    2,829
    1,305
    Hey!:D --- I've yet an entire complement of 1Lxx series SA plugin units -- and, I daresay, a few 525 'mainframes' somewhere...
    They may have been 'boat anchors' but giving them their due -- they were designed/constructed to higher quality standards than most equipment (in the $75K- $200K range) available today (if MTBF is any indication:mad:):):):)
    Best regards
    HP:)
  17. nsaspook
    Aug 27, 2009
    3,006
    2,348
    I remember the (happy) day we junked all but a few of the R-390s and replaced them with the R-1051. (that still had two tubes LOL)
    Maybe I worked too long in the Donut shop.
  18. nsaspook
    Aug 27, 2009
    3,006
    2,348
    That scope cart was build like a tank. I still have a few at work converted to custom mobile test racks.
    JoeJester likes this.
  19. KL7AJ
    Nov 4, 2008
    2,043
    292
    I've installed those too! FINE FINE radio...the synthesizer rocked.
  20. KL7AJ
    Nov 4, 2008
    2,043
    292
    I have TWO 545s with EVERY plug-in Tek made for them. :)
