i load the hex file to the pic but it is not working on board help help
angelita
Joined May 29, 2009
25
hi need help please
i want to program pic16f84A
i have pic-pg2 programmer
i used picpgm prgrammer software
when i connect the pic it detected ..i can program it and load the hex file successfully without error ..
but when i connect it to the board
nothing happened ...its like have not been connected at all
what is happeing here and how to fix this
thank you
t06afre
Joined May 11, 2009
5,934
Loading a hex file successfully to chip. Is not the same as the code will work as you want. And also serial based programmers are know to work now and then. Due to how many modern serial ports are constructed. I would as first step. Do compare/redback of the code that you have on your MCU. With the hex file on your computer. I am sure your programming software do have such options. If you have a match. Your programmer works. And it is your coding what is wrong. And that is most often. A far more simple task to fix
angelita
Joined May 29, 2009
25
i used the schematic and the code for Rickard Gunee pic game system
t06afre : i do as you say and i noticed when i read the code from the pic the first line was missing its seems like the name of the pic and the config ..
:020000040000FA ......the rest of the code are the same
how to fix this
Markd77
Joined Sep 7, 2009
2,806
It's possible you have to set up the config (first line of the hex file) in the software that you use to program the PIC:
From the faq in the zip file:
Q - How should I set the fuses when programming the pic ?
A - The bits are already set in the HEX-file, but some bad programming softwares doesn't understand it, in that case you should set it to: HS, wdt:eek:ff pwr:eek:ff cp:eek:ff
t06afre
Joined May 11, 2009
5,934
You can also erase the chip. And then do a blank check. If you are not able to erase your chip. Something is wrong.
t06afre
Joined May 11, 2009
5,934
is there a way to check if the chip is working or not
I think the problem is the programmer. The JDM type programmer are famous for instability. They may work on a computer with a old type RS232 port. But with a USB to serial converter the result may be very disappointing. You have sort of been scammed by purchasing this product. Get a PICKIT 2 or 3 instead
spinnaker
Joined Oct 29, 2009
7,830
t06afre gives good advice. You should get a PICKit2 or PICKit3. Yo will be glad you did.
The PICKit2 is not very expensive. It will not work with newer chips but there are still plenty it will work on.
Both PICKit2 and 3 give you in circuit debugging which is very useful The PICKit 2 gives you a simple logic analyzer.
angelita
Joined May 29, 2009
25
im not using usb to serial...im using the rs232 port on my computer !!!
by the way i erased the chip and every thing was successful ...also when i wrote the program to the
chip eveything was successful
is it possible that the problem is from pic >>>
t06afre
Joined May 11, 2009
5,934
Good the hear. By the way. The PIC16f84 is a old chip. You will find that the newer PICs are cheaper and better. With more functions. A good way to learn would be to port your games to a new chip
spinnaker
Joined Oct 29, 2009
7,830
That is good to hear. Congratulations! I been able to get PICs to work with erase before myself, though it usually does not require it.
You still might want to look at buying a PICKit2 or 3.
thatoneguy
Joined Feb 19, 2009
6,359
DIY programmers are often the cause of people getting frustrated and giving up on microcontrollers as "too hard".
A PicKit 2 or 3 through ICSP will program and debug a PIC, and will alert you of a failure in loading the firmware.
If the .hex code in the .ZIP file was written for the 16F84, it should work. It is VERY rare to have a bad PIC. It is very common to have a bad programmer, though.
angelita
Joined May 29, 2009
25
i want to try it with winpic - pic programmer but but there is a message says: couldn't initialize programmer
what shall i do
thatoneguy
Joined Feb 19, 2009
6,359
what shall i do
Solve most all of your problems
Everybody that gets one kicks themselves for trying to build a $25 hack that works with a handful of PICs when a $35 perfect unit can be purchased. In addition to programming, a PicKit 2 acts as a TTL serial interface and a logic analyzer to boot!
t06afre
Joined May 11, 2009
5,934
The JDM programmer type take power from the serial port. And many modern serial ports. Do not have have enough juice for that task. So the the programming voltage may be to low during programming. I have also read that some USB to serial converters mess up the timing.
