I just want help to understand this question on Op Amps
Discussion in 'Homework Help' started by nyasha, Feb 9, 2011.
  1. nyasha
    Thread Starter Active Member
    Mar 23, 2009
    90
    1 would also like to know what they mean by the maximum voltage by which the "virtual ground mode departs from its ideal value". The question is in the picture attached
  2. t_n_k
    Mar 6, 2009
    5,448
    783
    They probably mean the deviation of the voltage from an ideal 0V at the negative input terminal of the Op-amp - assuming the positive input terminal is connected to supply ground.
    At 0V input, the deviation would presumably be zero. The maximum deviation would occur when the input is either at +10V or -10V or both.
    I guess one assumes that it is a unity gain inverting configuration.
  3. elecidiot
    Jun 29, 2010
    23
    I seriously doubt the reply given by our friend t n k. There is no need to assume a unity gain or not. We know that Vout=A(open loop gain)*vd(voltage across 2nd and 3rd pin) irrespective of whether the opamp is in open loop or closed loop. So here the virtual ground node is nothin but the 2nd pin. The 3rd pin is connected stiffly to gnd. So in order to produce +10 V as output, the vd=Vout/A. Thus vd=10/2000=5mV. Here vd=Vin+ - Vin- = 0 - Vin-. So voltage at virtual gnd must be -5mV for this case. For Vout=-10 V it is vice versa ie voltage at 2nd pin is +5mV. I hope I make sense :)
  4. Georacer
    Nov 25, 2009
    5,151
    1,266
    I 'll agree with elecidiod on that one.
  5. t_n_k
    Mar 6, 2009
    5,448
    783
    I agree as well.
    I was mistakenly thinking the input to an inverting stage was +10V to -10V rather than the output being +10V to -10V.
