i have problem with arduino software.
Discussion in 'Embedded Systems and Microcontrollers' started by thanosgen, May 20, 2010.
  1. thanosgen
    Jan 15, 2007
    11
  2. retched
    Dec 5, 2009
    5,201
    313
    I would go to
    http://www.arduino.cc
    and check their forum. There is most likely an answer there.
    Are you using a 32bit or 64bit computer? You may be using the wrong version of arduinos software for the bit architecture of your PC.
    You can also try right clicking on the icon and find compatibility mode. Try running the program as Windows 2000, or even 98.
    But still, check arduinos forum. They have a bug-tracker that will most likely solve your problem.
