I have ORCAD, do I have PSPICE?
Discussion in 'General Electronics Chat' started by hp1729, Dec 14, 2015.
  1. hp1729
    Nov 23, 2015
    2,105
    235
    I have ORCAD 16.6. PSPICE stuff is mentioned but I can't get anything to run but the main PSPICE program. No *.DAT files. Do I just have the stripped down free version without PSPICE?
  2. eetech00
    Jun 8, 2013
    685
    118
    I don't use Orcad now but it is Pspice compatible. Orcad has its own file format. You probably need to import the pspice file to convert it.
    hp1729 likes this.
  3. hp1729
    Nov 23, 2015
    2,105
    235
    I have been to the Cadence web and downloaded PSPICE (I thought). I'm still struggling with it.
    I don't have any particular reason to use such software. It is just one of those things on my retirement list.
  4. mvaseem
    Member
    Jan 31, 2014
    48
    8
    Yes orcad is pspice compatible. I think it is pretty easy to use.
    You can launch "Capture" and open any sample design shipped along with.
    It should be located at - <install>/tools/pspice/capture_samples/anasim/example
    Just open the design and hit the simulation button.
    You can further edit the design to simulate your own circuit.
  5. hp1729
    Nov 23, 2015
    2,105
    235
    I think I may need to reload my orcad.
  6. mvaseem
    Member
    Jan 31, 2014
    48
    8
    Yes you might try again. Orcad demo always comes with Pspice. Just give a try. It should be easy to go with.
