I have an idea to convert ethernet to TTL, but I don't know how it's it.
Discussion in 'The Projects Forum' started by Iqbal Muhammad, May 19, 2016.
  1. Iqbal Muhammad
    May 19, 2016
    5
    is this forum still active? I'm newbee here and I have a same problem too.
    I have an idea to convert ethernet to TTL, but I don't know how it's it. I've seen a project to send data through serial port with hyperterminal and the cable was replaced with LED as transmitter and phototransistor as receiver. Data from serial was converted to TTL with max232.
    but ethernet is different from serial. I don't care with connection speed. But I want use TCP/IP protocol in Li-fi/VLC project. Is there any solutions? thx~
    Mods Note:
    This thread was split from -- Working on Li-Fi (or VLC), need some help here.
  2. Papabravo
    Feb 24, 2006
    10,340
    1,850
    You can use TCP/IP over a serial port. IIRC RFC #1055, by Romkey lays out a procedure for doing just that.
  3. Iqbal Muhammad
    May 19, 2016
    5
    @Papabravo is that kind of programs or hardware? sorry I'm still newbie in networking
  4. Papabravo
    Feb 24, 2006
    10,340
    1,850
  5. Iqbal Muhammad
    May 19, 2016
    5
  6. Papabravo
    Feb 24, 2006
    10,340
    1,850
    It can send and receive UDP frames. All the other protocols like TCP/IP and HTTP and FTP are built with similar structures. So the answer is yes.
  7. Iqbal Muhammad
    May 19, 2016
    5
