I have a trivial question about circuit
Discussion in 'General Electronics Chat' started by Manicarus, Apr 10, 2015.
  1. Manicarus
    Apr 10, 2015
    Hi, I am new here and I have a question to ask.
    Sorry that I couldn't upload the photo right next my question.
    It's in the "Attached Files" corner.
    In each circuit, there's a resistor and a battery.
    The two circuits are sharing ground.
    Is there current flowing through the line between the two circuits?
    I am not sure but I remember my professor saying that
    logically, there should be no current flowing through it
    but in reality, there's a current flow.
    Thanks.
  2. dl324
    Distinguished Member
    Mar 30, 2015
    3,376
    651
    Is this a homework problem?
  3. Manicarus
    Apr 10, 2015
    Nope, this is not a homework but I got curious about it when studying bipolar transistors.
  4. R!f@@
    Apr 2, 2009
    8,787
    771
    According to the diagram there will be no current flowing.
    Cause there is only one connection and no other path to complete the circuit.
    If there is a voltage difference between the batteries there might be negligible current flow.
  5. dl324
    Mar 30, 2015
    3,376
    651
    In an ideal situation, there would be no current because everything is at the same potential.
  6. Manicarus
    Apr 10, 2015
    Thank you guys!
  7. WBahn
    Mar 31, 2012
    18,085
    4,917
    What was the professor's reasoning for saying that there is a current flow in reality?
    If current is flowing in the line between the two circuits, where is it going? How is it getting back to where it started? If it isn't getting back, then one side is getting an increasingly positive charge and the other side is getting an increasingly negative charge. That means that a potential difference is building up that opposes further current? What mechanism is supporting this? Where is the necessary energy coming from to continue moving charge against this ever increasing potential difference?
  8. Ramussons
    May 3, 2013
    562
    92
    Mind explaining how?
  9. R!f@@
    Apr 2, 2009
    8,787
    771
    I said might due to a Potential difference. Just guessing .
  10. Ramussons
    May 3, 2013
    562
    92
    That guess is wrong. :D
    R!f@@ and ErnieM like this.
  11. R!f@@
    Apr 2, 2009
    8,787
    771
    So tell us what you know. After all, isn't that why you are here.
  12. KMoffett
    Dec 19, 2007
    2,584
    234
    As WBahn said there is no return path for current to flow into and out of the single common connection. Each battery/resistor is a closed loop. There is no potential difference between the wire going into the common from the right and the one from the left. There may be a potential difference between the left end of R1 and the right end of R2, but again there is no return path for current to flow....as in an open circuit.
    Ken
