I have a project to provide power using alternative energy
Discussion in 'The Projects Forum' started by shadi220, Nov 7, 2015.
  1. shadi220
    Apr 16, 2014
    Mod edit:
    Please don't hijack other member's post, now you have your own.
    This thread was split from -- DC to DC Boost Converter - 12V to 96V at >9 amps.
    I want to use solar panels with 12-volt battery and a circuit that I want to run manufactured Muthur will be connected to a pump water in areas that do not reach them the power supply Converter 12 to 120 or 100 2a
  2. shadi220
    Apr 16, 2014
    I used ic uc3845 and mosfet irf3205 to convertical 12vdc to 50vdc and output amp3very good but I need over than 50 v between 100 to 150v and amp at least3amp how can be that.
  3. shadi220
    Apr 16, 2014
    You circuit it's good but amp so very low do you can be over than 1 amp
  4. shadi220
    Apr 16, 2014
    Can you send to me diagramthis circuit
