I feel bad for asking but..
Discussion in 'General Electronics Chat' started by 1-3-2-4, May 21, 2013.
  1. 1-3-2-4
    Thread Starter Active Member
    Dec 26, 2008
    194
    I just got a new solder sucker which is my first one.. anyways I did not expect the spring to be so strong when I opened it.. so now I'm trying to put it all back together but I can't figure out how it goes back.
    Which way should the plunger be facing?I assume the spring goes in first?
    Haha nevermind I got it.. silly mistake
  2. t06afre
    May 11, 2009
    5,939
    1,222
    One thing. Remember to clean up your suction pump quite often. As it gets filled with solder you will loose suction
  3. sheldons
    Oct 26, 2011
    616
    101
    Desolder braid is better......
    shortbus and ErnieM like this.
  4. 1-3-2-4
    Dec 26, 2008
    194
    I have all three.. I always used my solder bulb and I've never had an issue with it..
    anyways so cleaning it, each time I ready it for use the last use of solder I sucked up gets thrown out.. I assume that's normal? auto cleaning? Since not many point that out.. at least I'm trying it on something that's not important.
  5. ke5nnt
    Mar 1, 2009
    384
    15
    Mine does the same. Never had a problem with it. Also never had much luck with the braid, which is why I got the sucker in the first place.
    1-3-2-4 likes this.
  6. 1-3-2-4
    Dec 26, 2008
    194
    I'm still on the fence right now kinda liking the braid better because it's faster for me depending on joint size.
    The thing is when it's time for the solder to eject out of the sucker I might have to manually pull a round cylinder piece of solder out just because it does not fully eject.
