I don't know how to start
Discussion in 'Homework Help' started by ][ Shocked ][, Jun 14, 2009.
  1. ][ Shocked ][
    Apr 13, 2009
    Hello eveybody,
    I have a design problem and it's taking a big part of my classwork mark
    I didn't understand the problem
    it's described as following
    You have three sources with internal resistors,, respectively. You would like to design a circuit to perform the following operation:
    • State which circuit can perform such operation.
    • Design the circuit that performs such operation.
    • Justify all your answers.
    I just want to understand what is going on
    and what does that integral mean
    big thanks for the one who would help me
    and I will try my best to solve this problem, inshAllah
  2. mik3
    Feb 4, 2008
    To perform this function you have to use a summer amplifier (op amp) with a gain of 1000 followed by an integrator circuit.
  3. ][ Shocked ][
    Apr 13, 2009
    I'm getting the half of the idea now
    but the other one is still away from me
    the integral here, what's does it physically mean?
    my math is so bad
    and thx alot for helping ^^
  4. steinar96
    Apr 18, 2009
    An integrator opamp works "similarly" to an integral because it "integrates" the voltage such that, the longer an input signal is applied the more output it puts out. Even though the output signal is a constant.
    An integral isnt anything physical really. It's just a symbol that represents the summing of infinitelysmall amounts of something. In this case it just "implies" that your circuit should use an integrator since it works like a integral, integrating the input signal and outputing something that is some kind of a sum of voltage inputs over time.
  5. ][ Shocked ][
    Apr 13, 2009
    ok im getting it now
    but still one question
    should I work wit dc sources or with ac sources?
  6. hgmjr
    Jan 28, 2005
    I would start with DC sources until you get a clear understanding of what is going on.
    Are you using simulation software in this investigation?
  7. mik3
    Feb 4, 2008
    The problem does not specify so you can use both AC and DC.
    In practical applications a DC source will drive the integrator into saturation after some time thus you need to keep the capacitor discharged all the time with a transistor and let it work when needed. This happens with AC too due to noise in the op amp.
  8. ][ Shocked ][
    Apr 13, 2009
    it's my first course in EE
    and we don't have transistors
    and capacitors are there, but not with op amp
    and yes, I could use a simulation software
    my real problem is with that integral
    what does it mean?
    does it mean my output voltage is
    ( v1+v2+v3 ) * 10?
    sorry for asking so much and thx alot for helping guys ^^
