i dont have a 9 pin connector in my pc for pic programming
Discussion in 'General Electronics Chat' started by leonheard, Jan 23, 2013.
  1. leonheard
    Jan 8, 2013
    48
    hi!
    i have a pic 16f84 microcontroller, and i need to make a circuit ( programmer ) to connect it to the pc... but i dont have a 9 pin connector female o male in my pc! i dont even have a printer pins.... what can i do?
    can i use the ps/2 mouse, keyoboard connector for programming? ( i can solder and stuff.. )
    will this simple circuit work? for me?
    http://sfprime.net/pic16f84/index.htm
    or if u have better give me link please :)
  2. nerdegutta
    Dec 15, 2009
    2,565
    805
  3. tshuck
    Oct 18, 2012
    3,531
    675
    Seconded... I bought a non-pickit PIC programmer, programmed a few, then wanted to use more sophisticated PICs, out went the programmer and I bought a Pickit 2. I still don't know what happened to that programmer....
    Pickit 3 can program all of the PICs, so, get that one...
  4. spinnaker
    Oct 29, 2009
    5,062
    1,159
    tshuck likes this.
  5. tshuck
    Oct 18, 2012
    3,531
    675
    In my defense, I got it to program parallel EEPROMs, then discovered it could program PICs...:)
  6. leonheard
    Jan 8, 2013
    48
    okei, thanks for the info :D hmm but why is that circuit carbage?
    i thought that it only had to send information to the pic microcontroller from the pc. not playing with it xD
  7. tshuck
    Oct 18, 2012
    3,531
    675
    It's because it can only program, what 4?, PICs, where the Pickit 3 can program all of them... there are a LOT!
    Your money is better spent on a device that can program the devices you will probably be moving toward anyway...
  8. spinnaker
    Oct 29, 2009
    5,062
    1,159
    Don't know why they are carbage but it is garbage because it does not program all of the chips but more important, it could be full of flaws. Either in the original design or something you did during building.
    It might work one time but not another. The PicKits have been around for years. This is no guarantee you won't have problems with every single chip but if you do, you know you can get support from Microchip. Try that with your home built programmer.
    Also most of those programmers just program and not debug. The Pickits can do in circuit debugging, a huge benefit.
  9. leonheard
    Jan 8, 2013
    48
    Great! thanks alot....
  10. ErnieM
    Apr 24, 2011
    7,433
    1,623
    If that is what you have and your funds are limited you can get a USB to serial converter... they sometimes work <grin> depending on your OS.
  11. leonheard
    Jan 8, 2013
    48
    well... i bought today that usb to serial converter ( usb to rs232 ) , and tried many diy programmers... didnt work :/ i even put some external power supply +5v, like this
    http://sciencezero.4hv.org/electronics/com84.htm
    ps. the +5 volts i use it external, from a battery, not from the Usb to rs232
  12. takao21203
    Distinguished Member
    Apr 28, 2012
    3,577
    463
    I am too lazy and too tired to give the schematic, anyway, I don't have the URL. It is a website from Argentinia.
    I modified it a bit.
    The 12V programming voltage is generated from batteries!
    You only need 1mA.
    I must say I never use it, but it works for some 16F PICs.
  13. spinnaker
    Oct 29, 2009
    5,062
    1,159
    Buy a Pic Kit II or III.
