I cannot find this formula
Discussion in 'Homework Help' started by junyan, May 13, 2008.
  1. junyan
    May 13, 2008
    7
    Please help me discover the proper formula to use in the following question:
    Objective : Magnitude of Total Current in Amps.
    Parallel RLC circuit contains 4 ohm resistor, a 0.281 H coil and a .25 uF capacitor connected across a 15V, 60HZ source.
    Thank You for you assistance!
    J
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
  3. roddefig
    Apr 29, 2008
    149
    I would find the total impedance of the circuit and then use Ohm's law to find your current and take the magnitude of the result.
    I did the math and came up with approximately 3.75 amps.
  4. junyan
    May 13, 2008
    7
    I would like to thank both of you for your response. I really appreciate the two of you taking the time out of your busy day to help me. Roddefig, I also got 3.75 amps as the answer.
    Thank You!
    J
