I am trying to find info about capacitor and failing miserably, help!
Discussion in 'General Electronics Chat' started by shteii01, Mar 14, 2015.
  1. shteii01
    Thread Starter AAC Fanatic!
    Feb 19, 2010
    3,500
    511
    What I know:
    - electrolytic capacitor
    - can shape
    - 6.3 volts
    - 220 uF
    - KZG (series?)
    - (M) (possibly +/- 20%)
    - not really clear on the size, say 6-8mm diameter, 10-12mm height
    I did find data sheet for KZG series by United Chemi-Con, but it does not list 220 uF... Help!
  2. cmartinez
    Jan 17, 2007
    3,698
    2,752
    What's so important about it having to be the same exact capacitor? There are plenty of other caps out there from other brands with the same characteristics that you've mentioned
  3. shteii01
    Feb 19, 2010
    3,500
    511
    I am looking for ESR, impedance, ripple current info.
    And yes, when I looked at digikey and mouser, I selected 6.3, 10 and 16 volt caps. So I am looking at wider field.
  4. cmartinez
    Jan 17, 2007
    3,698
    2,752
    Oh... so you're not trying to replace it then? You're trying to find its info?
    I'll see what I can find
  5. cmartinez
    Jan 17, 2007
    3,698
    2,752
    Can you post a picture of the capacitor?
  6. studiot
    Nov 9, 2007
    5,005
    515
    Electrolytics often have a date or date code?
  7. cmartinez
    Jan 17, 2007
    3,698
    2,752
    It seems that the KZG series start with a minimum capacitance of 800 µf, are you sure it's 220 µf and not 2200 µf?
  8. shteii01
    Feb 19, 2010
    3,500
    511
    Actually I am going replace two of them.
    Ok. Funny story time.
    So I bought 4 ram modules from ebay to upgrade my pc. It is Intel 975X chipset, 8 GB ram max. Turn of my pc. Open case. Insert 4 modules. I m excited and I want the magic numbers to appear so I don't close the case, just hook up monitor, keyboard, mouse and power. Push the On button... the light behind the On button comes on, but nothing else... try just one module, nothing. Try one of my old modules, that worked just fine just a few minutes ago... nothing. Finally started checking the caps (I had bad cap on another motherboard before)... found one bulging cap. Started taking out the parts so I can get mobo out of the case... took a hulking GTX 460 video card out... there is another bulging cap under it. The two bulging caps are identical. So now I am going to replace two of them. The end.
  9. paulktreg
    Distinguished Member
    Jun 2, 2008
    621
    124
  10. cmartinez
    Jan 17, 2007
    3,698
    2,752
    Well, that EZG series caps are stated as ultra-low ripple type, low ESR and impedance. Why not just use caps from other manufacturers with the same characteristics? Also, I'd use higher voltage caps to replace those two... there has to be a reason why they bulged out, and a higher voltage spec will protect them a bit more.
  11. shteii01
    Feb 19, 2010
    3,500
    511
    It is 220 uF. I will post pic in a little bit.
    This thread is from 2010: http://www.badcaps.net/forum/printthread.php?t=10358
    I am not the only one with 220 uF KZG.
  12. shteii01
    Feb 19, 2010
    3,500
    511
    Umm... we come full circle... what is the ultra low ripple, ESR and impedance for the 220 uF cap that IS NOT listed in data sheet?
  13. cmartinez
    Jan 17, 2007
    3,698
    2,752
    Good point. I'd look at other brands and compare their characteristics to similar values (other than the 220uf you're looking for) and see how well they match.
  14. shteii01
    Feb 19, 2010
    3,500
    511
  15. studiot
    Nov 9, 2007
    5,005
    515
    The datasheets for the KZG series came out in 2002 and were revised in 2003.
    These only show the 800mu, as you say.
    But I would not be suprised to find the range was subsequently extended.
    They are not listed in the Nippon Uni-Chemi-Con list of obsolete series, but nor are they listed in the 800 page 2014-2015 current full catalog.
    (at least I can't find them).
    However there is a US number so why don't you call Tech Services and ask?
    Alternatively if you can find an earlier full catalog , say about 2006 -2008 they may (should?) be in there.
  16. shteii01
    Feb 19, 2010
    3,500
    511
    I ordered two of these: http://www.mouser.com/Search/Produc...1virtualkey64700000virtualkey647-RHT1A221MDN1
    higher temp rating
    higher voltage rating
    relatively low impedance
    relatively high ripple current
    I hope they work. I really did not plan on building/buying another pc. I can... but I don't want to.
  17. studiot
    Nov 9, 2007
    5,005
    515
    Yeah those caps in the photos look easy to change.
  18. cmartinez
    Jan 17, 2007
    3,698
    2,752
    They should work, PC's have many redundant components in their circuitry to make them more reliable. One thing you could do is add a small X7R cap (about 0.1µf) connected in parallel with each of the electrolytics. That should take care of the smaller ripples and transients.
