I am trying to build an ecg generator circuit. which generates ecg waves on its own
Discussion in 'The Projects Forum' started by pavan.revenkar, Feb 13, 2011.
  1. pavan.revenkar
    Feb 11, 2011
    i need help from any1 regarding wat kind of circuit can i use... i have written the program in matlab so if anyone could help me with this... please do its urgent
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    One suggestion we made with a similar request is to record ECG's into audio files so they can be played back.
  3. pavan.revenkar
    Feb 11, 2011
    do u ve circuit diagram of that... if please.... mail to my id i would be very glad <snip>
    Moderator's note: These are public forums and we insist that all questions and answers be done in the public view.
  4. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    What is the nature of the output of your ECG equipment? If it is analog, it can be recorded through a computer's sound card.
  5. pavan.revenkar
    Feb 11, 2011
    i am still building it i am confused with what circuit shall i design whether to build with dsp processor or by wave shaping circuit.. so if u could help me i would be very happy
  6. t06afre
    May 11, 2009
    5,939
    1,222
    Using a sound card to record ECG is not optimal. As the sound cards is AC coupled. And hence has a cut off around 15Hz. This will remove some of the lower frequency Content of a ECG signal. But if you only are interesting in doing heart-rate calculations. A sound card will work fine.
  7. t06afre
    May 11, 2009
    5,939
    1,222
    This is a ECG complex. As a start. You can repeat a ECG complex every time. And vary the interval between them. This will be a good approximation for a healthy person.
  8. pavan.revenkar
    Feb 11, 2011
    i get that.... the main problem is that how to design the circuit to get that output... wat are the components??????
  9. t06afre
    May 11, 2009
    5,939
    1,222
    Many solutions will be able to solve this problem. It is not one solution. Google is your friend. It is better that you do the research. Then come to us for help and comments
  10. CDRIVE
    Jul 1, 2008
    2,223
    99
    Are you aware that these are commercially made and certified?
  11. wayneh
    Sep 9, 2010
    12,374
    3,226
    The components are a Mac running GarageBand. Draw the trace, repeat it forever as "music". Done.
  12. KMoffett
    Dec 19, 2007
    2,584
    234
    Sounds like you are asking for an electronic ECG simulator circuit that you can feed to a MATLAB program for analysis. Is that the case?
    Ken
