Hi everyone I am new to Allaboutcircuit and this is my first post.
I read that electron are move out from a atom when heat or some some other force is affect/apply to the atom that is said to be positive charge. And other atom receive more electron is said to be negative charge. These two charges are try to get back it original state(exceed electrons go back to require) when there is some medium exist between them. And there is also a force(electrostatic) occur during these state.
I want to know
1- Is the force is bigger according to the difference amount of require and exceed electrons?
2- Is the Volt(pressure/ potential difference) same as above force?
I guess, the different(electron) is more bigger, the force will be more bigger. So high voltage can get from lightning(~1000V).
If my guess is right why the voltage and A are different in different battery and why my dc adapter can change different V with the same A.
I am not sure my getting knowledge is right. I read my electronic books for one week and some time I confuse with theories.
Can anyone help me to explain?
Thanks.
I want to know
Thanks.
