i am new to basic electricity
Discussion in 'Homework Help' started by Koky, Feb 28, 2010.
  1. Koky
    Feb 27, 2010
    4 loads are connected in series across 120volts and 3 ampere current exists.one load fail to perate.the voltage across each divece is 40 volts.what circuit fault is indicated?
  2. Heavydoody
    Jul 31, 2009
    140
    11
    Is there 40V across the load which fails to operate? Or only the other three loads?
  3. hgmjr
    Jan 28, 2005
    9,030
    214
    Have you taken a look at the material in the AAC ebook at www.allaboutcircuits.com ? I think it would supplement the material in your textbook nicely.
    hgmjr
  4. shteii01
    Feb 19, 2010
    3,500
    511
    Koky, the problem description you have provided is incomplete.
  5. bertus
    Administrator
    Apr 5, 2008
    15,798
    2,384
    If the voltage accross each remaining element is 40 Volts.
    How many volts are there accross the "defective" element?
    What is wrong with the "defective" element?
    Greetings,
    Bertus
  6. daviddeakin
    Aug 6, 2009
    207
    27
    It sounds like the answer must be "short circuit". An open circuit would result in 0V across each device.
