I am in the Dallas Area and need someone to build a circuit for me.
Discussion in 'The Projects Forum' started by ccmhover, Jan 26, 2011.
  1. ccmhover
    Jan 26, 2011
    I am a one man production shop. I need a unit built that runs a motor until a IR beam is broken, then the motor stops. The beam width would be 1.5" (mounted opposite each other on one end of a PVC 1.5" pipe. I have to mass produce a material that is opaque, and 1" wide x 2mm thick (that passes through the PVC pipe), and needs to be cut to the same length every time. I can build the machine part, just not the electronic circuit part. Once the Beam is broken (open), I would need the motor to stay off until either the beam is closed again or until the power switch is turned off. This would need to be plugged into a 110v receptacle & except for sensors, the motor, and plug, would need to be packaged into a project box with a power on light and on/off switch. no part of the unit would be subjected to heat, water, or light. The motor would be a 12v motor with a wheel attached to turn a rollerblade wheel.
    I can email you a diagram of what I have in mind, so that this makes sense.
    I have no electrical training or skills, or else I would do it myself.
    Please somebody help me. I will pay for everything. An estimate and contact information would be great.
  2. edgetrigger
    Member
    Dec 19, 2010
    133
    19
    1. What is the capacity of the Motor?
    2. Do you want the ckt to be enclosed in a powder coated metal box or in plastics?
    3. How many PCS do you want?
  3. ccmhover
    Jan 26, 2011
    I don't know anything about the capacity of the motor, I was thinking something comparable to a dewalt 18v drill motor.
    the powder coated box sounds better to me.
    Right now I need one, in a couple months I may need six more.
    Thanks!
  4. wayneh
    Sep 9, 2010
    12,406
    3,256
    With what precision do you need the system to work, I mean 1/8", 1/4", 2", etc?
    I'd be concerned with the IR beam strategy if you need close tolerances. Half inch is probably a piece of cake. One millimeter is probably impossible.
    On the upside, the circuitry is relatively simple.
  5. Wendy
    Mar 24, 2008
    20,772
    2,540
    What part of the Dallas area?
