Using all the numbers you gave me with a toroidal coil formula gives me 2.4 H. This is close enough to indicate that the 6H number is probably correct.Also My friend Steve and I estimated the length of wire about 18 feet.
Aram
36awg copper is about 1.4ohm / m, so 100ohm equates to about 70 meters, or 210ft. try to fit that much wire to a tiny core.Also My friend Steve and I estimated the length of wire about 18 feet.
i'm just trying to figure how this mystery inductor is a 6H toroid with just 18ft of wire on it.If you chose a pot-core instead of a toroid you will experience a lot less grief winding the inductor.
hgmjr
their ~6H coils have ohms in the 1,000'sIndeed they are commercially available.....looky here----->http://www.picoelectronics.com/plugin/pe57_59.htm
These are pot core inductors....probably wound with 64 ga wire!
Eric
What you might try is pleading with the Renco guy. Tell him you only need one and could he please send you a sample. Also, ask him if there are any distributors who stock their stuff.Renco... doesn't look like it will pan out either after talking to their engineer. They do qty only.
Wow I wasn't aware that guitar PU's were 43 awg.. Actually how small can you draw copper wire???
Aram
Since you haven't unwound it, there's a possibility you could repair it. If the break is near the terminals, you could carefully cut away the urethane, and maybe fix it.Sorry DC:
My fault for not being clear... No I have not unwound it, I made a rough estimated calc, which is obviously wrong.
T
