Have started a knew job where plcs rule, I need to know more about them and how to determine if fault is Plc or external?
It's a Siemens used in a case erectorFirst what is the type/make of PLC?
So does it mean you have been thrown in the deep end with no experience of them?
The beauty of the PLC is the onscreen ladder makes diagnosis relatively easy, compared to the old relay logic panels, there are books out there but it helps to zero in on the type used where you are working.'
Max.
Sorry just bad predictiveI see in the post title you mention PIC's ? Some use the same terminology for both PIC's and PLC's.
Max.
Never worked with plcs everI see in the post title you mention PIC's ? Some use the same terminology for both PIC's and PLC's.
Max.
I must admit I had to Google 'Case Erector', worked on a few machines but had never heard of that one!It's a Siemens used in a case erector
