I am a complete noob and brand new to soldering
Discussion in 'General Electronics Chat' started by yourmom3882, Aug 3, 2016.
  1. yourmom3882
    Aug 3, 2016
    I was trying to make a 9 volt battery connector and this is my first time using my new soldering iron that i just bought today. I looked online and found what do to when you first get a brand new soldering iron which is to wait for it to heat up and then tin the tip which is what I did. But after my first few tries to tin a wire the tip started to turn black. SO now I don't know what to do or how to make it look clean again or if it really is a problem. SO PLEASE HELP. And any recomended channels or tips on how to better at soldering would really help.
  2. #12
    Nov 30, 2010
    16,694
    7,335
    1) wipe it on a damp sponge.
    2) get used to it looking black where you don't use the hot part.
    3) This belongs in, "Chat". I'll tell the moderators.
    4) you're supposed to tin the tip AS it heats, not after it's done getting hot.
    yourmom3882 likes this.
  3. yourmom3882
    Aug 3, 2016
    Thanks man I really appreciate it.
  4. #12
    Nov 30, 2010
    16,694
    7,335
    5) I prefer a small, "chisel" tip. Your mileage may vary.
  5. m zaid
    Member
    Jan 9, 2016
    46
    5
    I'm a beginner myself, but my suggestion may be worth a try as it worked for me. That black i'll call it carbon layer develops when the tip gets very hot. What I did with mine was too pull tip out an inch. I thought the excess surface where it is air cooling sorta maintains the temperature at the tip...
    If the tip's surface got black as well and it doesn't melt the tin, I rubbed it against the jaws of a long nose plier.
    wait, was yours temperature controlled already?
  6. yourmom3882
    Aug 3, 2016
    Yea it had been turned on for like about 10 minutes . Or can you explain what temperature controlled is???
  7. m zaid
    Member
    Jan 9, 2016
    46
    5
    I asked whether was your soldering iron the temperature controlled type. In the background of your picture there a station with a knob, resembling a variable temperature soldering station iron. I have no experience with those to relate with the black occurrence.
  8. #12
    Nov 30, 2010
    16,694
    7,335
    "Temperature controlled" means you can control the temperature. For instance, that knob with red on its top end.
  9. nigelwright7557
    May 10, 2008
    488
    71
    You have to keep on wiping the tip on a damp sponge and keep tinning the tip after each few joints.
    #12 likes this.
  10. joeyd999
    Jun 6, 2011
    2,757
    2,931
    For tips that cannot be cleaned on a wet sponge and re-tinned, carefully sand the black parts off with 600 grit sandpaper (while cold), and immediately tin as the tip gets hot. This will work a few times.
    I always leave a drop of solder on the working part of the tip if I am going to leave the iron hot and unused for a minute or longer. Then, wipe and tin just before use. Tips will last a very long time if you do this religiously.
  11. #12
    Nov 30, 2010
    16,694
    7,335
    I think I should have elaborated about the fact that wiping and re-tinning is a continuous part of soldering. Your tip will not stay pristine for a whole minute when you are actively soldering. The usual is:
    1) Pick up the soldering iron,
    2) wipe the tip, touch a tiny bit of solder to it, approach the joint,
    3) go to step 2.
    Sometimes you can do 5 joints in a row before you have to wipe again.
    90% of soldering (and painting) is preparation and cleanliness. You only have to prep and clean once to paint a room, but you have to wipe the soldering tip a hundred times on a busy day.
  12. MrSoftware
    Oct 29, 2013
    545
    133
    When it gets really rough looking and wiping on a wet sponge doesn't do the trick anymore, you can sometimes clean it up with tip tinner. There's a number of them out there, here's one example:
    https://www.amazon.com/Thermaltroni...g_3?ie=UTF8&psc=1&refRID=8ENS6832XADVG7XPC5P8
    IMHO it's easier to solder after some of this stuff wears off (the stuff I have doesn't allow solder to stick to the tip very well), but it does help to clean it up which gets you back in the game. You gently press your hot iron into it and it melts and chemically cleans the tip. It smells horrible when melting, but works. :)
  13. Kjeldgaard
    Member
    Apr 7, 2016
    73
    17
    I also had a bad habit of wiping the soldering tip off when I put the soldering iron back in the stand.
    And this habit makes that there is only a very thin layer of tin to protect the soldering tip for a long time.
