hysterisis in a comparator circuit
Discussion in 'The Projects Forum' started by pona, Apr 11, 2011.
  1. pona
    Jun 21, 2010
    5
    I have attached a comparator circuit. I want to add hysterisis on non-inverting input. How can I do that?
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
  3. wayneh
    Sep 9, 2010
    12,405
    3,256
    Welcome to the forums.
    When you post a circuit, we'd appreciate a picture file - such as png, pdf, pict, etc. - as opposed to a Word doc. It's much faster to take a peek.
    Have you read the datasheet for a comparator, such as LM339? They will usually include an example of applying hysteresis
  4. pona
    Jun 21, 2010
    5
    thanks alot
  5. pona
    Jun 21, 2010
    5
    How can i increase the switching speed of this circuit?
  6. wayneh
    Sep 9, 2010
    12,405
    3,256
    Feed it a faster signal?
    You need to supply a LOT more info for anyone to help you. You haven't specified any parts or circuit details. How do you know you need faster switching? What are you really trying to do?
  7. SgtWookie
    Jul 17, 2007
    22,183
    1,729
    Increase the speed of WHICH circuit? You need to post a schematic of which circuit you are talking about, preferably in .PNG format.
  8. pona
    Jun 21, 2010
    5
    Sorry. I have attached the circuit now. The inverting input changes at a slow rate and the output of opamp changes in the form of ramp. I want to decrease the time it takes to change levels.
      File size:
      16.4 KB
      24
  9. SgtWookie
    Jul 17, 2007
    22,183
    1,729
    Try it like this instead.
    See the attached.
  10. shortbus
    Sep 30, 2009
    4,098
    1,697
    Also using a dedicated comparator(393 or 339) will do away with the ramp on the output. Output will be a square wave, and will work with a single rail supply.
  11. SgtWookie
    Jul 17, 2007
    22,183
    1,729
    Those comparators require a pull-up resistor, as their outputs are open-collector.
    Pull-up Ohms ~= Vcc/4mA
  12. pona
    Jun 21, 2010
    5
    thanks a lot for the help
