quick question about setting hysteresis on the ad594. in the datasheet (http://www.analog.com/static/imported-files/data_sheets/AD594_595.pdf) they show a resistor from Vout to pin 3. i understand its 200nA per degree C, but in their setpoint controller uses basis comparator to bring Vout high if the setpoint is exceeded. so i have a couple of questions:
1. how does hysteresis work if the injection current is only present when Vout goes high?
2. how to determine resistor value for a specific hysteresis? would it not be better to use a voltage ref IC and resistor to feed the hysteresis injection pin?
