Hyperlynx - plane impedance
Discussion in 'Programmer's Corner' started by kbmanick, Jan 6, 2012.
  1. kbmanick
    Jan 6, 2012
    I am using Hyperlynx 8.1.
    I created a Multiple layer PCB. I am not able to edit the Zo value of plane. Even If I change the Z0 value to zero, it automatically changes to 75 ohm.
    In general, Z0 is zero for ground and power plane.
    It will be helpful If I get a support.
  2. bertus
    Administrator
    Apr 5, 2008
    15,798
    2,384
    If you are a registrated user, you can find the help here:
    http://supportnet.mentor.com/
    If you are using an illegal version, you are out of luck.
    Bertus
