Hyper terminal
Discussion in 'General Electronics Chat' started by salim18, Jan 5, 2012.
  1. salim18
    Dec 24, 2010
    12
  2. Markd77
    Sep 7, 2009
    2,803
    594
    I had a look around and searched for "seagate tmos". I'm guessing that any USB to serial converter will work (they are pretty cheap on E-bay), but you would have to make a cable from the standard serial connector to the HDD.
    You might have to do a bit of measuring (there's a few different sizes) and figure out which pins connect where, but probably something here will do the job for the HDD end:
    http://www.rapidonline.com/SearchResults.aspx?kw=pcb%20interconnect
    However, don't blame me if it explodes, this is mostly guesswork.
