Hyestresis problem
Discussion in 'General Electronics Chat' started by TAKYMOUNIR, Nov 28, 2012.
  1. TAKYMOUNIR
    Thread Starter Active Member
    Jun 23, 2008
    351
  2. WBahn
    Mar 31, 2012
    18,079
    4,917
    Could you PLEASE, for ONCE, at least TRY to answer your own question and show SOME work, instead of expecting people here to be your no-effort-required-on-your-part answering service?
  3. Dodgydave
    Jun 22, 2012
    5,133
    767
    Well the voltage on pin 2 is 40 volts at 40Kv, and 2Volts at 2Kv, with the values of R4 & R5, so it will be 10Volts at 10Kv.
    So it wont work!
  4. TAKYMOUNIR
    Jun 23, 2008
    351
    Hi in this circuit i need my hestresis between 6 V and 1 so when vin is more than 6 v the vout will be low and when vin decrease and reach 1V vout will be high
    so i did the calculation as following
    i let R3=10K ohm
    AND WHEN VIN REACH 6V I WILL HAVE
    4v/R2+(15-6)v/R1=6v/10K ohm
    AND WHEN VIN REACH ZERO
    9v/R2-1v/R1=1v/10K ohm
    AND I SOLVE THESE 2 EQUATION FOR GETTING R1 AND R2
    MY QUESTION IS THIS TRUE AND IF I NEED MY HYSTRESIS FROM 6 VT 0V WHAT THE SECOND EQUATION WILL BE
  5. WBahn
    Mar 31, 2012
    18,079
    4,917
    Thank you for finally showing some work! (Next perhaps you can work on using a meaningful thread title).
    You equations look good, other than you obviously don't believe in tracking your units, which I harped about more than once. If you want any assistance from me in the future, you better use your units.
    Without a negative supply someplace, you can't get a threshold of 0V. Even if you could, you could have problems getting enough overdrive to ensure that it transitions.
    TAKYMOUNIR likes this.
  6. bertus
    Administrator
    Apr 5, 2008
    15,796
    2,383
    I have merged the threads, to keep the things together.
    Bertus
  7. TAKYMOUNIR
    Jun 23, 2008
    351
    is my calculations is true
  8. spinnaker
    Oct 29, 2009
    5,062
    1,160
    I think Wbahn wants you to rewrite it to, include units, to make the formula more readable. You need to do a better job at helping others to help you including providing as much information as possible and stop creating multiple threads on the same subject.
    But these are common sense things that are common on almost any forum. They shouldn't need to be mentioned by other forum members, you should already know this.
  9. TAKYMOUNIR
    Jun 23, 2008
    351
    i write the units
  10. WBahn
    Mar 31, 2012
    18,079
    4,917
    As I said, the equations looked good, other than the units.
    What steps, if any, have you taken to check your own work?
  11. takao21203
    Distinguished Member
    Apr 28, 2012
    3,577
    463
    Hi takimon,
    I hope your C stuf woks out.
