I recently moved and I'm unshelving a project I started on in '06.
I need to pulse 12VDC current in the (high) MHz range but I don't have the knowledge to build the circuit.
I have worked on simple electronics up to and including 555 timers and RaspberryPi GPIO, I simply don't have the electronics knowledge to know where to start as far as the components are concerned. I've been told I can do this with NAND gates, PWMs and Mosfets, however I would like the best / least complex method for accomplishing the pulse.
