Hydraulic Valve Control Circuit with 0-5k pot control
Discussion in 'The Projects Forum' started by ZipperJeremy, Feb 2, 2009.
  1. ZipperJeremy
    Feb 2, 2009
    I need a circuit that uses 0-14.5 Vdc to control a valve that is 20W (at 12Vdc). I purchased a 0-5K ohm electric bike handle grip. The grip looks like it can only handle 0.5 Watts. I have tried to use a 2SC4793 NPN transistor with a voltage divider to control the base. I am not having any luck with this. The transistor will only output 0-6 Volts. I used one transistor to power a second transistor but that didn't work very well either. Has anyone seen any circuits like this, or could you point me in a better direction?
    Thank you.
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Can you post up the schematic of your circuit? We can make much better guesses with that in hand.
  3. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Try it like this:
    You'll likely need a heat sink on Q1.
  4. mik3
    Feb 4, 2008
    4,846
    63
    I think a valve can only be switched on and off (not something intermediate), does it?
  5. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Mik3, I think you're on to something.
    At least if it's a pressure regulator valve. A chopper circuit would be much more appropriate - and much more efficient - along with being much more complex.
  6. mik3
    Feb 4, 2008
    4,846
    63
    ZipperJeremy give more information about the valve or its datasheet.
