Hybrid parameter model - common emitter
Discussion in 'Homework Help' started by mentaaal, May 19, 2008.
  1. mentaaal
    Thread Starter Senior Member
    Oct 17, 2005
    451
    Hey guys, just wandering something before my analogue test tomorrow, in the hybrid parameter model given in the attachment by our teacher, he says that the output impedance is 1/hoe (this is Zo) in parallel with Rload. But to me it looks more like it should be Zo//Re + Rload. As Re is in series with Rload and Re + Rload is in parallel with Zo. Could someone please tell me whats going on?
  2. mik3
    Feb 4, 2008
    4,846
    63
    Re is not in series with Rload. Now if Re is bypassed by a capacitor then we assume the capacitor as a short circuit at AC signals so the output impedance is as your teacher says. if not is more complicated.
  3. mentaaal
    Oct 17, 2005
    451
    Hi mike, thanks for the very very quick reply, could you please explain why Re is not in series with Rl? If hfe is regarded as being a current source then current can go through 1/hoe or through Re+Rl making them in parallel. Or at least thats how I see it. Could you point out where i am wrong please?
  4. mik3
    Feb 4, 2008
    4,846
    63
    Now i am confused too!!!
  5. mentaaal
    Oct 17, 2005
    451
    Ha Ha I hate it when that happens! Nothing in the world has given me as much grief as bloody transistors!
  6. mik3
    Feb 4, 2008
    4,846
    63
    The current through Rload and Re is not the same. Re carries a bit more current than Rload because of the input voltage so they are not in series.
  7. mentaaal
    Oct 17, 2005
    451
    True, Re carries base current as well as collector current but from the current source's perspective, that shouldnt change my notion that 1/hoe // with Rl + Re?? The current that the current source motivates in the model that goes through Re goes through Rl as well so Re should be in series with Rl.....
  8. mentaaal
    Oct 17, 2005
    451
    Could this case be only with the assumption that a bypass capacitor has been placed across the emitter resistor? Perhaps my lecturer means this because its such common practice? I would just ask him but i dont have him anymore this semester as the semester is over...
  9. The Electrician
    Oct 9, 2007
    2,301
    339
    To find the output impedance of the full circuit you need to do a full nodal analysis. The existence of a non-zero value for hre (reverse voltage transfer ratio) causes some of the output voltage to be fed back to the base, and then the presence of Rsignal and Rbase allows a current on the base side, which complicates the output impedance expression.
    The attachment shows the output impedance for the full circuit and then for several simplifications such as setting hre to zero, removing Rsignal and Rbase, and finally removing re, which for ac signals would be the same as bypassing it with a capacitor.
    The last impedance shown is in fact just 1/hoe in parallel with Rload.
    The output impedance with all the parameters in place is probably not much different than 1/hoe || Rload, but you would have to evaluate the more complicated expressions with numerical values to find out.
