b.shavir. I'm not sure you understand the mechanics going on here...
Pee is not a stream, rain is not a stream, they are individual droplets seperated by LARGE distances of empty space. There is no conduction path. You could drop a bucket full of pure copper beads and the same thing would occur, absolutely nothing. Each individual air gap adds with the distance between the source of the voltage and the destination so either the voltage would have to be absolutely massively high (high tension wires) or the distance would have to be already extremely short. If you could fill 50% of the space between an HV conductor and a discharge point you would only double the distance you could get shocked from.
Look at the typical water flow from a small hose over any distance greater than about 6 inches and you'll see that there is no conduction path, just water droplets traveling in a common path.
