Hurricane Issac Help
Discussion in 'The Projects Forum' started by remout, Aug 28, 2012.
  1. remout
    Apr 18, 2011
    14
    Guys,
    I live just north of NOLA, I've still got Internet and power.
    I've got a radio that uses 8 "D" batteries. I'm thinking they are 1.5 volts which would be 12v total 8 x 1.5 = 12. If I'm thinking right, can I power this from a 12v car battery?
    The radio has two rows of batteries one with 3 and one row with 5. The radio is plastic so I can't take it apart but I can get to the contact points of each row of batteries. Any advice on if this would work and how to wire it up?
    I've got some wire, solder, and misc project connectors and stuff.
    Many thanks!
  2. JohnInTX
    Jun 26, 2012
    2,394
    1,051
    Inspect the battery compartment. The D cells should be stacked button end (+) to flat end (-) to add the volts of each cell to 12V total. If there is more than one row you'll observe that each row is a different direction and each end but the very ends of the D cell stack are connected to keep the cells in series. The ends of the D cell stack are +/- 12V. Connect the (+) from the car batt to the D cell button end of the stack and the (-) end to the D cell flat end.
    If you have a cigarette lighter plug you can get 12v from that too.
    Be careful as the car battery can deliver enough current to melt wires / cause fires if they short. Fuze it if you can.
    Mods: sorry if this falls under automotive mods. Handle as necessary.
    Good luck! Be careful and stay dry. Are you sure that instead of cannibalizing the car you shouldn't be hitting the road?
  3. remout
    Apr 18, 2011
    14
    Okay, I understand and I can fuse it up. I'll be using a battery not in a car.
    Thanks for the quick response, not sure how long I'll have Internet.
    Thanks again!
    Bob
  4. crutschow
    Mar 14, 2008
    13,521
    3,390
    A transistor radio running on a fresh set of "D" batteries will likely operate for at least a couple hundred hours.
  5. remout
    Apr 18, 2011
    14
    Good to know, I won't mess with mine until I have too.
    Many Thanks!
