HundaTech 4.3" I2C TFT DISPLAY (PLEASE HELP)
Discussion in 'Embedded Systems and Microcontrollers' started by brandonLA, Apr 25, 2016.
  1. brandonLA
    Apr 25, 2016
  2. ErnieM
    Apr 24, 2011
    7,435
    1,625
    That looks like a graphic display, I can't be sure since I don't speak that language. You need a ton of support code to even get one of those to say "hello world."
    Look for some example code to get that display running. Once you get that displaying some numbers will be the easy part.
    And welcome to the forums!
  3. dannyf
    Sep 13, 2015
    2,196
    417
    You will need a datasheet to get started.
  4. mcgyvr
    Oct 15, 2009
    4,785
    973
    Sure its possible..
    All the information is in the datasheet to write your own library or get stuff going (if you are familiar with talking to a display without a library)..
    Can you take a picture of the back so we can see if the controller is used on another TFT that already has a complete library done for it?
  5. brandonLA
    Apr 25, 2016
  6. dannyf
    Sep 13, 2015
    2,196
    417
    Sounds like you have all that's needed to get it going.
