I'm working on a human pulse detector, which must be applied to read the pulse at the radial artery (wrist).
For this I'm basically using a LDT0-028K piezo sensor from Measurement Specialties, Inc. The output of the piezo sensor is connected to a charge amplifier whose simulation circuit is shown in the figure.
The amplifier has been tested on breadboard and seems to be working fine. The sensor works fine as long as it is vibrated manually. However there is no output to the wrist pulse, I've tried different configurations of placing the sensors;clamps, wrist straps, etc. But no matter how much tight i hold the sensor there is no pulse pick up.
Could you help me troubleshoot?
I have very little time to complete this project...
I'm wondering if the sensitivity of the sensor is low. However, there are a couple of project papers where they have used the same sensor.
Can you give any suggestions for better sensors? Or the configuration so that noise due to human motion is reduced and pulse pick up increases?
Thank You.
Thank You.
