Hum on hi gain. Cause?
Discussion in 'The Projects Forum' started by Bigbizkit, Dec 26, 2015.
  1. Bigbizkit
    Oct 29, 2015
    44
    Hi made a bass preamp by Elliot Sound.
    I am having problem eliminating the hum.
    Everytime I turn the volume control up, the hum gets louder.
    And when i increase the gain level, it produces a hissing sound.
    But @ lower volume/gain, the preamp is working fine.
    I am planning to put a voltage regulator using 7815,7915.
    Wondering if it will work
    Note: my wiring arrangement is messy,
    Im thinking its one of the reasons why my project is noisy!humming.
    http://sound.westhost.com/project152-1.htm
  2. bertus
    Administrator
    Apr 5, 2008
    15,796
    2,382
    You could use this circuit from the same site:
    http://sound.westhost.com/project05a.htm
    You can connect the AC inputs to the AC15/1 and AC15/2 connections in the given powersupply circuit of the project.
    You will likely not need the auxillary supply given in the preamp supply project.
    Bertus
  3. Dodgydave
    Jun 22, 2012
    5,127
    766
    You need to use a pcb really for amplifiers, veroboard is notoriously noise prone with stray capacitance. If you can post the circuit, and have a separate audio amp to test the preamp output.
  4. DickCappels
    Aug 21, 2008
    2,745
    665
    That is an impressive looking circuit board!
    Yes, it is a very good idea to use a regulated power supply for your preamp because the opamp has a a finite Power Supply Rejection Ratio.
    You might want to go back and re-read the author's advice about the power supply "The power supply will not be inexpensive..."
    Hum can also be picked up by capacitive coupling from AC mains wires near the circuit. Some shileding might be required. I've noticed that the fast transitions on the output of triac lamp dimmers, in this case a soldering iron power control, is one of the worst offenders.
    Hum can also result from getting the power supply grounds "mixed up" with the signal grounds, resulting in a ground loop.
    About the hiss: There will always be some hiss, the challenge is to make it so low that you don't notice it. Since the design is by Elliot Sound a safe working assumption is that the design is good. If, when you set the gain to its normal working range and the hiss is still objectionable then you might have a damged opamp (assuming you are using the opamp version of the preamp). One of the potentiometers might be noisy.
    Bigbizkit likes this.
